Voice Recognition for Climate Control
Old Oct 6, 2007 | 10:18 AM
KAHBOOM's Avatar
KAHBOOM
Super Moderator of Pwnage
Angry Voice Recognition Missing Commands Comfort/ Convenience Options Changed
I can get every voice command to respond except for the sub-commands sugch as temperature controle etc... which is the majority of the commands the system has... Are there any settings that need to be adjusted to get it to work?
Old Oct 6, 2007 | 10:35 AM
ghideon's Avatar
ghideon
I think the command is "temperature XX degrees." It's worked for me, somewhat. Did you do the voice training in the menu?
Old Oct 6, 2007 | 02:27 PM
sanscu's Avatar
sanscu
First say: "Climate Control"
Car (SexyMama) responds: "Climate Control ON"
Then say: "Temperature 70 degrees"
SexyMama responds: "Temperature 70 degrees"
You're set and try not to break out in a sweat. Cheers.
Old Oct 6, 2007 | 04:19 PM
KAHBOOM's Avatar
KAHBOOM
hmmm still no luck for me. I went through the training menue and then when I checked for available commands there is no "temperature" command... wierd
Old Oct 6, 2007 | 08:00 PM
KAHBOOM's Avatar
KAHBOOM
As I have further investigated, I see that most of my voice sub-commands are missing. Is that possible? I guess the dealership will need to upload them (?)
Old Oct 7, 2007 | 09:42 AM
KAHBOOM's Avatar
KAHBOOM
ok so I checked in on the Sedan Forums and ther ewas a TSB on the Sedan for missing voice tags. I guess this may apply to my coupe as well (?)
Oh well back to the dealership...
http://g35driver.com/forums/showthre...ing+voice+tags
Old Oct 8, 2007 | 04:34 PM
shumby's Avatar
shumby
I had that problem in the 6MT i took for a test drive the other day but did not get a chance to play with it more. let us know how it turns out.
Old Oct 8, 2007 | 04:58 PM
g35newbps2's Avatar
g35newbps2
I just picked up a g37s a few days ago. My car finally came in... Anyhow I checked mine out and it doesn't recognize the temperature setting for me either. I've already done the training. I'm assuming that it's missing that command. Has anyone called the dealership to find out what's up? I might give them a call today.
Old Oct 8, 2007 | 06:24 PM
Brent72's Avatar
Brent72
I'll be picking up my new G on the 20th so I'm interested to find out if this is a widespread problem.
Old Oct 8, 2007 | 09:19 PM
KAHBOOM's Avatar
KAHBOOM
The Sales Associate stated that he had a nother car on th elot that also had that problem. They are communicating with Infiniti about the issue to see what needs to be done.
For those of you having the problem, please help us all out by bringing up to your dealer. The more phone calls Infiniti gets regarding it, the quicker that they will likely respond.
Old Oct 8, 2007 | 10:35 PM
tomcatm's Avatar
tomcatm
Temp command works for me.
Old Oct 9, 2007 | 01:55 AM
gan78mao's Avatar
gan78mao
this only works wit the nav right?
i would liek to have this if it works on the premium too.
Old Oct 9, 2007 | 10:50 AM
marsb007's Avatar
marsb007
works for me. I do have the nav... can't test a non-nav model.
Old Oct 9, 2007 | 01:09 PM
g35newbps2's Avatar
g35newbps2
I think they need to do an update on the car some of the voicetags are missing. I'm going to call my dealership today and ask them what's up.
Old Oct 9, 2007 | 01:28 PM
gan78mao's Avatar
gan78mao
my voice dial isnt working very well either. should i bring it in to check? whenever i saw a number it comes out another.
