Nitrous Build Begins ....(Finally)
Old Dec 25, 2011 | 04:45 PM
NeverBoneStock's Avatar
NeverBoneStock
So after a lot of research I am finally ready to start putting this thing together .. One of the most difficult things I had to do was research proper gauges and nitrous control unit ... I will be molding a GlowShift universal triple gauge pod to my drivers side pillar.. It was 20.00 shipped on Ebay. I will be wrapping both driver and passenger pillars in perforated leather to have a much cleaner look and match my interior.. Here is the 3 gauges I chose......
Innovate DB series A/F Wideband gauge (Blue Digital)
DB Gauges: Air Fuel Ratio Guage
AutoMeter Cobalt Series....(Blue Digital) Nitrous Pressure Gauge and Fuel Pressure Gauge............
AutoMeter Cobalt Digital Series Gauge
For the Nitrous controller I went with Harris Speed Works MicroEdge Controller......
Harris Speed Works**Nitrous Controllers**Nitrous Window Switches & Timing Controllers**The MicroEdge Nitrous Controller
This will be installed by me starting on Wed.. I have everything here and will have the daunting task of molding and wrapping my pillars and the fun of installing gauges and the Nitrous controller .. After that I will be installing the bottles and routing everything .. Should be fun .. I think ????????????????? Also, could be a major fail...
Old Dec 25, 2011 | 04:59 PM
G37Sam's Avatar
G37Sam
Will you be getting us dyno numbers??
Old Dec 25, 2011 | 05:02 PM
NeverBoneStock
Yes sir .. After I install everything off it goes to be tuned ...
Old Dec 25, 2011 | 05:50 PM
RYs06MT's Avatar
RYs06MT
Hit me up I'm just sleeping all week, I'll come help out. I still need to get those lugs from you as well.
Old Dec 25, 2011 | 05:53 PM
NeverBoneStock
No problem .... Let's knock it out ..
Old Dec 25, 2011 | 06:06 PM
RYs06MT's Avatar
RYs06MT
Sounds good I can't wait to see your new goodies
Old Dec 25, 2011 | 09:19 PM
ANMVQ's Avatar
ANMVQ
Nice man!! Cant wait for pics, numbers and total $$$, Will be a good compare betweem FI and Nitrous,, BTW the gaude pod , Your not worried about your side impact air bag? If god for bid is has to deploy?
Old Dec 26, 2011 | 12:10 AM
NeverBoneStock
I thought about it and it's one of those things that I would have to deal with if it did ... Hopefully not ...
Old Dec 26, 2011 | 12:55 AM
eksigned's Avatar
eksigned
NICE! Good luck man! Curious though - you've done all the research, so I'm only asking for your opinion. Will you (honestly) be able to run nitrous safely? ie no detonation issues, no internal engine issues, etc.? is it any more detrimental to the engine than say, high revs (under load).
Old Dec 26, 2011 | 01:11 AM
NeverBoneStock
From talking to countless people , shops and tuners it will be safe .. Just like any other application it will come down to the tune .. The nice thing about juice is I can use it only when I need it . Running on a stock block and doing it safely will be no problem ..
Old Dec 26, 2011 | 10:46 AM
DjFromVA's Avatar
DjFromVA
cant wait to see the results, good luck dude
Old Dec 26, 2011 | 11:19 AM
AJQuiles's Avatar
AJQuiles
Very intresting. Love to see the outcome. positive all the way . Good luck.!!!
Old Dec 26, 2011 | 02:32 PM
Steve561's Avatar
Steve561
Ill wait to see your results, maybe ill try to do it to my car next haha, Good luck!
Old Jan 2, 2012 | 05:58 PM
NeverBoneStock
So Wed. has come and gone ... I have been busy with some other things . Started the molding of my gauge pod to my driver side pillar. Bought some bondo and plastic weld from home depot . I placed my universal gauge pod on my pillar to find the location I liked best .. Took the pillar off and started taking all fabric off of it .. Next I placed the gauge pod on the pillar again and took my heat gun and started to warm up the plastic of the gauge pod to conform to the pillar. I than scuffed the areas of the pod and pillar that would have contact and
glued them together . I put screws in 4 different locations to get a nice bond between the two... Let set for 24hr and trimmed all the excess gauge pod with a dremel ... Next is the Bondo !!!!!!!!!
Attached Thumbnails Nitrous Build Begins ....(Finally)-img_1955.jpg   Nitrous Build Begins ....(Finally)-img_1956.jpg
Old Jan 3, 2012 | 02:07 PM
DjFromVA's Avatar
DjFromVA
lookin good keep it up!
