Sway Bar question
I have an 09 journey sedan and swapped out eibach sways f & r with aftermarket stock end links. Haven't had any problems. I'm a believer that when you upgrade, you should upgrade everything evenly or you upset the balance of the vehicle... i.e., if you go alot faster then you should be able to stop just as quickly.
Does anyone know if the SPL front end links fit on the X sedan?
I plan on dropping on fortune 500 coilovers w/swifts and extenders, f&r camber kits, hotchkiss f&r sways, cusco STB and I wanted to upgrade the end links too. If anyone can tell me if that will work or not that would be great. I want to bang out my entire suspension all at once.
