Help "push" in rear
Old Jun 6, 2025 | 10:35 AM
LMR's Avatar
LMR
"push" in rear
My local tuner shop said I could run into a "push" in rear by going with a staggered 9.5 / 10.5 +22 offset. They recommend 8.5 +30 / 9.5 +35. I'm looking at ESR AP5C wheels for my 2011 coupe sport RWD on stock suspension. Anyone ever heard of this before and is it accurate? Any opinions are welcomed and appreciated..
Old Jun 6, 2025 | 02:14 PM
projectpanda13's Avatar
projectpanda13
"push" as in understeer pushing? Running staggered at the limit can have this tendency.
What's weird is they say that about the staggered combo of 9.5" / 10.5" but their recommended 8.5" / 9.5" is the same staggered variation.
Did they mean to suggest a square 9.5" +35? This is a good spec to run if you want to go with a wider tire without excessive camber to fit them.
Old Jun 6, 2025 | 02:33 PM
Upgrade your swaybars, and understeer pretty much goes away, irrespective of the staggered fitment. I've got 8.5" in the front and 10.0" in the rear, and I don't push.
Never heard that term used for understeer. Makes sense, though.
Old Jun 7, 2025 | 07:21 PM
LMR's Avatar
LMR
My first thought was they were referring to poke. They said G37s have a narrower rear end than say a 350z which is more suited for a 9.5 /10.5 set up.
I always forget that while the wheelbase is a little over 10 inches shorter, that the Z is wider than the G by roughly 3 inches.
Old Jun 8, 2025 | 08:48 AM
projectpanda13
depending on the offset, you can have the same fit with the 9.5”/10.5” combo as the 8.5”/9.5” combo
8.5” +30 = 9.5” +43
9.5” +30 = 10.5” +43
fitment is at the fender of course.
Old Jun 8, 2025 | 10:26 AM
socketz67's Avatar
socketz67
Community Builder
AMP_01
Apr 2, 2024 10:48 AM
IracknBack
Jun 17, 2017 10:51 AM
jameswouldgo
Jun 2, 2016 11:17 AM
MNDZA
May 4, 2010 07:53 PM
ironchef2008
Oct 7, 2008 09:34 AM
