this wheel spec will fit your 2013 awd sedan no problem. it'll be slightly sunken in. this a new wheel purchase? I would suggest choosing somehting a little more aggressive.
Are you stock height?
Thanks for responding projectpanda. Yes, I am at stock height and I don't want to make any modifications. 17" wheels are on it now and I just wanted to give my G a sportier look with the 18" wheels.
It will fit, but won't be perfect. I'm on 18"s on my X, 9.5 wide with +28 offset, and its flush lowered 1.2" Looking at my own car, going 8 wide takes away 0.75" on each side, so you're going to be sunken in a good amount. May require spacers if you want it to look flush-ish. 19"s may also look better at stock height than 18"s because the X is half an inch higher than the Journey and the 6MT.
Since your car is at stock height, the offset may not be as visible because of the gap and less camber, but It wont be perfect, probably about half an inch to an inch sunken in depending on how wide of a tire you go with. Just so you can picture it, this is my fitment with 18x9.5+28 on 255/45/18 tires:
