Wheels & Tires Reviews on wheels & tires for G vehicles.
Wheel offset
Old Jan 20, 2022 | 09:13 AM
FancyZ's Avatar
FancyZ
Wheel offset
Hey guys, I'm going to be getting niche m204 vosso's for my g in the spring, and I want to make sure the offset is right. Looking at 20x9 in the front, and 20x10 in the back, what should I be looking at for offset? As of now the car is on stock suspension and has the sport brake kit. When I eventually do lower the car a bit, it won't be much. Thanks!
Old Jan 20, 2022 | 02:30 PM
sobeIPL's Avatar
sobeIPL
I’m no expert but I’ll try to help. Without moving to the extremes, I think you want something between +25 (aggressive / sticking out / meaty look) to +45 (more conservative, doesn’t stick out). Mid 30s is probably a safe median but do your research, I’m not an expert.
Old Jan 20, 2022 | 04:08 PM
Birdie's Avatar
Birdie
What tire size are you wanting to go with?Figure out while wheel and tire combo you want then your offset can be figured out a bit better.
Old Jan 20, 2022 | 04:28 PM
FancyZ's Avatar
FancyZ
Well I'm not sure, what mm fits a 10 and 9 inch wheel? Probably a 245/40 and 255/40.. or a 245/35 or 255/35..
Old Jan 20, 2022 | 05:18 PM
stealthee's Avatar
stealthee
245 and 255 are too narrow for proper fitment on a 10" wheel. 245 just barely fits on a 9" wheel
Old Jan 20, 2022 | 05:19 PM
FancyZ's Avatar
FancyZ
okay so 255 265 then?
Old Jan 21, 2022 | 12:21 AM
Birdie's Avatar
Birdie
This is a 255/40 on a 10 inch wide tire. So this is what it will look like. As far as a 9 inch wide tire the factory spec on a sport model is 245/40 on the rear.im sure you can find plenty of photos on line of how it looks. I'm not sure what your end goal look is.Nice fat tires for traction or slim for looks.find out how you want the look to be then we can get a better offset figure.
Old Jan 21, 2022 | 03:48 AM
Birdie's Avatar
Birdie
Just to clarify is this going on a coupe or sedan?
If a coupe you are looking at
Front 20×9 +27
Rear 20×10+40
depending on your tire size on rear you may have to trim a small piece off the bumper bracket.
Old Jan 21, 2022 | 07:06 AM
FancyZ's Avatar
FancyZ
I have a 2012 coupe. As for what I'm looking for, I don't really need the extra traction, it's more of a situation where I just like how that will look with a wider wheel on the back.
Old Jan 21, 2022 | 11:32 AM
Birdie's Avatar
Birdie
Not sure what you mean by wider wheel. If you want the wheel closer to being flush I think a 255/35 all around would work out good.
If you want a fat tire look, a 285/30 on the rear is a next good option.
Old Jan 21, 2022 | 03:10 PM
FancyZ's Avatar
FancyZ
I kinda just like the aggressive look of a wider wheel setup in the back is all
Old Jan 22, 2022 | 01:14 PM
FancyZ's Avatar
FancyZ
Alright, so o figured out the offset I need thanks to fitment industries, now I just gotta figure out exactly what size tire I need to run. My car won't be on air, sometime I'll be getting either coilovers or lowering springs for it, but I don't ever plan on "slamming" it, I had a civic like that once and hated it. I also don't want to roll/pull/trim the fenders either.
Old Jan 23, 2022 | 11:22 AM
FancyZ's Avatar
FancyZ
just an FYI, I have the 2012 g37xs, and the factory tires are 225/45's all around
donscastle
Nov 5, 2019 01:41 PM
yowaddup_G
Apr 28, 2011 12:16 AM
ben_ben125
Jan 23, 2010 02:39 PM
