38mm or 45mm offset
Old Nov 4, 2019 | 09:59 PM
donscastle's Avatar
donscastle
38mm or 45mm offset
Hello, Looking at Mach ME.15 wheels for a stock 2008 G37 18x8. The options are 38mm or 45mm offset. Standard tires 225/50.
Read about offset, mostly seems to be of concern when changing the wheel size. A few online sites say 38mm for this wheel. My math head says 45mm is closer, so less change, from the stock 43mm.
Which offset would you recommend? Does it make much of a difference given that everything is stock?
Thank you.
Old Nov 5, 2019 | 03:22 AM
Said Amir's Avatar
Said Amir
I would do 38mm it will just push the wheels out a bit, but it will look really weird having it pushed in more by getting 45mm. If you are to get 38mm it won't affect much of the geometry since your hub is still close to the center of the rim. If you really want to visualize the amount it will stick out if you go with 38mm offset just grab a 5mm wrench and place it next to your wheels on the car.
Old Nov 5, 2019 | 01:41 PM
donscastle's Avatar
donscastle
Thank you Said. I just ordered the wheels with +38mm offset.
BigBadWolfe
Mar 7, 2017 01:11 PM
Rhythm_X
Feb 9, 2016 01:10 PM
slowmkv
19
Feb 9, 2011 09:49 PM
ben_ben125
Jan 23, 2010 02:39 PM
