Help TPMS Relearn Question
Old Aug 31, 2019 | 03:45 PM
Zot's Avatar
Zot
New poster/G37 owner here. I've had my 2012 G37xS for about a month now and this forum has been great at helping me learn how to DIY when it comes to maintenance. (The G is my first car, so it's been fun working on it and learning how to do things) So about a week ago I went to fill my tires as I was moving to California. However, the previous owner had put metal caps on the valves and a few had corroded and become stuck. I learned the hard way and ended up snapping one of the valve stems. Unfortunately the only tire shop open on a Sunday was Walmart and they could only install a regular valve stem.
I ordered an OEM TPMS sensor online. (Pacific 407001LA0C) Took it in to Pep Boys to get it installed this morning and after installing it they said it wasn't sending a signal and they couldn't do anything. My guess is that Pep Boys wasn't following the correct relearn procedure, but I could be wrong. Can TPMS sensors with the G be finicky to relearn or did I just continue my steak of bad luck and got a bad sensor? TIA
Old Aug 31, 2019 | 04:15 PM
ILM-NC G37S's Avatar
ILM-NC G37S
First, is the sensor you bought new/used/refurbished and was it bought from a reputable seller?
The newest part number for your TPMS sensor is 40700-1LA0E, not C. It is possible the sensor you bought is dead (if you bought it "new" then it could be old/deadstock). If Pep Boys can't get a signal from the sensor then that is the likely culprit. Unlike other cars, the sensors in the G are bare bones basic units: they either send a signal "I'm working" or they don't.
EDIT: You can try the self-registration protocol as documented in the factory manual, if that fails then you likely have a bad sensor:
Old Aug 31, 2019 | 04:42 PM
Zot's Avatar
Zot
I bought it online from the website tpmsdirect.com. Unsure how reputable they are, but I'm guessing now not so much.
I didn't realize the updated the sensor, I just simply ordered the same sensor that was in the wheel to begin with. Thanks for the help though! I'll go ahead and start looking for another sensor.
Old Aug 31, 2019 | 05:00 PM
ILM-NC G37S
I almost always deal with discountinfinitiparts.com for parts. Prices are reasonable and customer service exceeds top notch. Real Infiniti dealership in Atlanta metro area.Just a suggestion, no affiliation.
I found the sensor for $65 (TPMS Sensor- New): IF you want OEM:
You might find them cheaper elsewhere or even on eBay.
Good luck!
Old Aug 31, 2019 | 07:56 PM
Surfnazi's Avatar
Surfnazi
Discount tire can do it
HMG37
Nov 16, 2017 11:00 AM
eddy7r
Jan 7, 2017 08:15 PM
Blkout
Feb 7, 2013 02:12 PM
ashmostro
Jul 24, 2012 01:09 PM
Fezzik
Dec 16, 2010 01:23 AM
