Rim Fitment
Have a chance to purchase a set of 2015 Mustang GT OEM 19 staggered wheels (front 19x9 with +45 offset, rear 19x19.5 with +52.5 offset). Will these work on my 2013 G37S coupe? Yes the bolt pattern is the same as the G (5 x 114.3) and will need hub-centric rings (they are available in plastic or aluminum). Only concern is lug nuts.
Not sure if the factory mustang wheels use a mag-type or a conical seat lug nut, just have to look up OEM lug nuts for the year Mustang you're getting.
You will also probably want spacers to bring them out a bit as those offsets are pretty conservative. You might also need them to clear the Akebono brakes on your S coupe.
Onurb
Jun 11, 2013 06:40 PM
BlitzKrieg32
Jun 24, 2011 03:36 PM
