Offset/Wheel Width
Old May 19, 2019 | 11:14 PM
Coilovers are the way to go if you plan on long term, just keep in mind you will have a noticeably firmer suspension that will take what little luxury the G may have out of the equation. I'd take a look at Ksport, get pretty decent reviews here and there's quite a few that run them. If you go all-in w/ complete front and rear camber sets and coilovers you'll be in the $1500 range (with alignment factored in) if you are willing to DIY the install.
And the price would go down about $350 if you get just the rear camber/toe set.
As far as how much life is left in the OEM dampers, hard to say, depending how the Gs been driven they could be about halfway through their life or almost toast.
Old May 19, 2019 | 11:18 PM
Bossman360's Avatar
Bossman360
What's your thoughts on the swift spring koni damper combo? Sounds like I'd keep the smooth ride but not have the ability to adjust for the around the same price?
Old May 20, 2019 | 08:21 AM
That combo is great, but Koni doesn't have an AWD application
AFAIK there aren't any aftermarket performance dampers available for the X platform
Old May 20, 2019 | 01:49 PM
Bossman360's Avatar
Bossman360
Ughhh that is an absolute bummer.... I guess that makes my decision an easy one since I dont wanna just put a bandaid on it with springs only to end up needed coils sooner than later...
ngan202
Mar 22, 2013 04:13 PM
nycty
Nov 26, 2012 08:25 PM
AroundTheG37
Nov 14, 2011 01:45 PM
MNDZA
May 4, 2010 07:53 PM
jedmonds
Mar 16, 2008 11:57 PM
