Help Fitment Questions
Fitment Questions
I have a 2009 g37s coupe and I am wondering if this would be a decent setup , car is completely on stock suspension but have tein coilovers on the way and want to know a decent setup for this wheel? Spacers, fender rolling , recommended tire size ? Thanks
Run 255/40 front 295/35 rear and the extra tire width should fill the fenders to make up for the slightly more conservative offsets. Must confirm brake clearance though since you have the big sport calipers.
That last set will be aggressive~very flush w/ probably a bit of poke at in-spec camber, depends on the look you're after. The first set will be easier overall to get a more standard fit except for brake clearance, more aggressive sets "typically" have more room behind the spokes for big brakes. If you go w/ set #2 narrower tires will help, like a 225/45 front 255/40 rear.
el_donks
Intake and Exhaust
Mar 28, 2016 10:23 PM
flyingmachine
Jul 27, 2015 11:15 PM
DenisTheMenace
Oct 2, 2013 12:53 PM
