Staggered?
Old Feb 26, 2019 | 03:21 PM
thugginnuggets's Avatar
thugginnuggets
Staggered?
I need some assistance with getting the right wheels.
I drive a 2008 G37 RWD, and I had staggered wheels before but all the warning lights came on before (VDC, Slip, Tire Pressure, NO check engine light though) and these lights only came on when accelerating.
Do I need to get different size wheels or is there a computer that can be reconfigured to address these lights?
Old Feb 26, 2019 | 06:22 PM
stealthee's Avatar
stealthee
What size tires were you running front and rear?
Old Feb 26, 2019 | 11:02 PM
CJ1957's Avatar
CJ1957
To better understand your issue, could you provide your present front and rear wheel and tires sizes? Also, does your car have the sport option? If you have the sport option, the wheels and tires sizes should be front 19 X 8.5” wheels with 225/45WR19 tires and the rear 19 X 9” wheels with 245/40WR19 tires.
Though you could easily have wider tires with the fronts at 245/40-45WR19 and the rears at 265/40WR19. And with spacers, I think the stance would look a lot nicer with 10mm’s in the front and 15mm’s at the rear which would fill out the fender well better. JMHO.
Old Feb 27, 2019 | 01:23 PM
slartibartfast's Avatar
slartibartfast
Check your brake fluid level before you do anything else.
apocalyps101
Jun 22, 2012 01:50 PM
laklein
Sep 28, 2009 05:24 PM
lenZG35
Picture Share G Coupe
Sep 11, 2007 08:50 PM
