What kind of tpms sensor should I have?
Old Jul 9, 2018 | 10:38 AM
rotarymike's Avatar
rotarymike
Moderator in Moderation
My new 2013 6MT came with aftermarket crappy wheels, but it had the oem wheels in the trunk/back seat. Just had the bald tires dismounted so I could clean/prep/paint them, and they just have the rubber snap-in valve stems.
Do our cars use the clamp-in style (there is a metal collar with seal on the outside of the wheel) or snap-in style (the sensor bolts to the bottom of the valve stem inside the wheel?
Old Jul 9, 2018 | 11:08 AM
Entcee's Avatar
Entcee
OEM TPMS have the sensor at the bottom of the valve stem.
Old Jul 9, 2018 | 11:43 AM
rotarymike's Avatar
rotarymike
thanks - that's the sleeve type (the metal sleeve is the part immediately below the valve cap that has a hex drive surface on it).
This is what I was referring to: (sleeve here is called the nut)
Clamp-in vs. Snap-in style TPMS Sensors
Old Jul 11, 2018 | 06:29 AM
Surfnazi's Avatar
Surfnazi
They are generic in a sense the ones at discount tire will work with your car. There isnt a Nissan made sensor, just a company Nissan uses for their use on build.
Old Jul 11, 2018 | 11:57 AM
slartibartfast's Avatar
slartibartfast
It's my understanding that there are five types. Discount Tire can tell you which you need.
jsampsell
Nov 4, 2014 03:25 PM
jsampsell
Sep 2, 2014 11:40 AM
Andrew@SonicMS
Wheel & Tires
Oct 5, 2012 09:21 AM
ZOSTER33
12
Jul 7, 2012 10:38 PM
theresamarie1
Jan 11, 2011 02:21 PM
