Putting 19" Staggered Sport Wheels on AWD G37 Sedan
Old Apr 30, 2018 | 07:26 PM
Cx Hatch's Avatar
Cx Hatch
I am new to posting but not new to the site. I own a 2013 G37xS. Sorry if this has been posted before, while I was researching this topic I could not find the answer I was looking for on here. I saw a few "Maybe" or "it should work" but nothing definite.
I recently purchased a set of 08 G37 Sport Wheels and tires. The REAR tires were 245/40ZR19 and FRONT were 235/35ZR19. I installed them on the car, NO SPACERS NEEDED...Just an easy bolt on job. They looked great compared to my 18" Factory "crow foot" wheels.
I went for a drive and my AWD light started flashing on the freeway and to be honest the car felt a little squirrelly. After some research I pulled the awd fuse and drove the car throughout the weekend. FINALLY after the weekend I went to my nearest discount tire for 2 new front tires. (The front and rear tires must be the same size for these setups to work on these AWD cars. 2 new tires later, the problem is solved.
The staggered wheels WILL work on AWD G37 Sedans BUT you must have the same size tires all the way around. I now have all (4) 245/40ZR19 and my G37XS drives perfectly, NO more awd light issues.
There is no need to buy 2 sets of wheels to make this work (rim width is not really an issue) JUST GET THE SAME SIZE TIRES ALL AROUND AND THIS WORKS PERFECTLY!
Old Apr 30, 2018 | 07:30 PM
slartibartfast's Avatar
slartibartfast
Plenty has been written about coupe wheels on AWD models. You do NOT need the same tires front and rear, you need same DIAMETER tires front and rear.
Old Apr 30, 2018 | 07:41 PM
Cx Hatch's Avatar
Cx Hatch
Yes, that is what I said. Put the SAME SIZE TIRES ALL THE WAY AROUND.
Sorry if this has been posted before, I personally could not find anyone with ACTUAL EXPERIENCE in this situation when doing my searches. Only people who had a good estimation it should probably work.
Please delete post if this information is so common, I searched 3 days and never found a direct answer.
Old Apr 30, 2018 | 09:53 PM
Welcome to the site.
If you do have the coupe staggered 19" wheels the stagger is so minimal that for AWDs it is best to put the same tire size on all four like a 245/40/19 that you're running.
Here's a list of staggered sets that will work on AWD~
FWIW Here's the best tire combos I'd recommend for 18s/19s/20s, then pick proper wheel widths/offsets to get them to fit~
18s
235/45 & 265/40 (0.07%)
245/45 & 275/40 -0.07%
255/45 & 285/40 -0.22%
19s
225/45 & 255/40 0.06%
235/40 & 265/35 -0.37%
235/40 & 275/35 0.67%
245/40 & 275/35 -0.52%
245/40 & 285/35 0.51%
20s
235/35 & 275/30 0.07%
245/35 & 285/30 -0.07%
This calculator should be used when trying new setups~
Keep in mind the variances with a minus sign have smaller rear diameters, this isn't as good since the rears wear faster, this will cause the variance to increase over time. Not a big deal when you're starting at zero or close, but if you're already almost at 1% variance this needs to be considered. None of the above combos should have enough rear wear to be a issue but
Old Jul 23, 2018 | 05:45 PM
K33LAN's Avatar
K33LAN
I recently put on some Niche Essen 19x8.5 35 offset and 19x9 40 offset on my G37xs Sedan. It seems to be fine, but I called Infinity to be sure and the service department freaked me out with Infiniti doesn't condone it and it could mess up your transmission. Kind of rattled now...Should I be concerned and looking for some new rims?
Old Jul 23, 2018 | 07:43 PM
slartibartfast
As long as you have a front/rear tire diameter difference of less that one percent, you're fine. Brad provided an extensive list in the post previous to yours.
Old Jul 29, 2018 | 11:33 PM
RxRyanM's Avatar
RxRyanM
No, that's not what you said. There's a difference. 245/40/19 and 285/35/19 are virtually the same diameter, but not the same size. Same size would obviously be 245/40/19 and 245/40/19.
Old May 7, 2020 | 06:52 PM
ChervilB's Avatar
ChervilB
i have a 37x and just bought me some 19” Nismo rays staggered, so 245/40/19 at the front and 275/35/19 at the rear and that shouldn’t turn on my awd light?
Old Jul 23, 2020 | 02:48 PM
dirtnapper56's Avatar
dirtnapper56
You will be fine. Even if the light comes on, that means your car is turning off the AWD because it senses the size difference due to different rotational speeds, etc.
I run this combo on my car and have no issues with AWD light. 245/275 combo has a .52% difference in diameter between them, so you are okay because it is less than 1%
Old Aug 21, 2020 | 03:13 AM
dirtnapper56
Originally Posted by mummy2
What you wrote is actually 52 percent. You meant .0052%.
no man, I meant 0.52% as in a little over one half of one percent. 275/35 is ~half a percent smaller than 245/40
Old Aug 27, 2020 | 04:23 PM
toocozycarloz's Avatar
toocozycarloz
Tire Specs for my g37x AWD Sedan
I was just curious i just got some g37s coupe wheels 19x9 all around but the tire specs are 235/40/19 in the front and 245/40/19 in the rear should that turn on my awd light??
Old Aug 27, 2020 | 05:41 PM
dirtnapper56
if you have awd then yes it will. The tire diameters need to be the same front to rear.
v36_g35x
Jun 25, 2019 02:26 PM
meebu
Sep 18, 2016 07:24 PM
isosunrise
Feb 11, 2016 12:21 PM
czardini
May 9, 2014 07:37 PM
angeljr8282
Apr 17, 2014 09:01 AM
