Wheel spacers advice
Old Apr 11, 2018 | 09:13 PM
lester_vq37's Avatar
lester_vq37
I’ve been hesitant on getting wheel spacers for my 08 G37S Coupe. I get mixed opinions on wheel spacers like like, “wheel spacers are bad for your wheel bearings and suspension geometry” or “there should be no problems if installed correctly”. At certain angles, I don’t like how the wheels are not flush with the body. The wheels are a bit too “inside the car” if you get what I mean. I just want my car to have a little more of an aggressive stance. My car is running stock ride height with stock suspension, 245 tires all round. What would be the best width spacers? I’m looking at 10mm front and 15mm rear OR 15mm all round. If I were to get spacers, what kind of long term effects on the wheels, suspension, etc, should I look for and what kind of maintenance should I do as I have these spacers? Is there anyone who’s had or currently have spacers if there’s any problems or no problems at all?
Thanks,
Old Apr 11, 2018 | 10:57 PM
Gio37's Avatar
Gio37
Not sure about your concerns but as a reference, here is my G "S".....same year/model as yours
20mm F / 15mm R
btw, also includes the Eibach Pro Kit installed
g/l
Old Apr 11, 2018 | 11:51 PM
lester_vq37
20mm F / 15mm R
g/l
Damn that looks clean af
im just concerned about wheel bearings wearing out faster when spacers are installed. As for maintenance, do you have to retorque the lug nuts on the spacers once in a while?
Old Apr 12, 2018 | 12:23 AM
Gio37's Avatar
Gio37
I did checked the spacers a few miles after the first install.
Will be removing them sometime at the end of the year when I replace the brake pads to resurface or replace the rotors....but the spacers are going back on
g/l
Old Apr 12, 2018 | 01:13 AM
user 3587587's Avatar
user 3587587
20mm F / 15mm R
g/l
Do you have extended lug bolts. I read on z1 that they are necessary for 15mm and up spacers. I was wondering if that was really true.
Old Apr 12, 2018 | 08:52 AM
You'll definitely need them for spacers thicker than 5mm, but most that run thicker spacers (15mm on up) use the bolt on spacers that use OEM studs and have their own wheel studs built in, much simpler install.
Old Apr 12, 2018 | 08:59 PM
lester_vq37
Thanks guys. I think I’m going with 15mm in the front and 20mm rear on stock ride height for now. I will eventually drop the car in the near future.
Old Apr 12, 2018 | 09:07 PM
lester_vq37
oh and btw, do you have any issues with your tires rubbing?
Old Apr 13, 2018 | 12:31 AM
Gio37's Avatar
Gio37
me....non at all
Old Apr 13, 2018 | 07:02 AM
carid's Avatar
carid
MYG37.COM Premium Sponsor
We're a vendor on this forum and we actually offer some nice wheel spacers for the G37 made by H&R. They are available in 3 sizes: 15mm, 20mm and 25mm thick. Check more information about this set on this page: https://www.carid.com/2008-infiniti-...-78874033.html
Old Apr 18, 2018 | 07:39 PM
Surfnazi's Avatar
Surfnazi
Just make sure your lug nuts will still grab enough of the wheel hub bolts
Old Apr 18, 2018 | 10:43 PM
Gio37's Avatar
Gio37
BTW - Here are a couple of great tips by Rochester:
Some tips:
Use a thin application of no-sieze compound between the hub and the spacer, and between the spacer and the wheel.
Before you do this dance again next year, clean the spacers down to the metal and start over.
Since you're going to be installing and uninstalling each year, don't use the crappy half-height, open lug nuts that come with your spacers. Spend a little extra and get some quality spline-drive lug nuts. Here are some pics. The lugnuts in the first pic... toss them in the trash.
Look at the lug nuts in the second pic... spline drive nuts from Gorilla which use every single mm of thread, and you won't ever have to worry about stripping the heads. Which you will do with the little ones, guaranteed.
Original post LINK
Old Apr 18, 2018 | 11:15 PM
lester_vq37
Old Jan 12, 2020 | 11:57 AM
sjw944's Avatar
sjw944
One piece of advise. My Ipl
has 20mm on fronts and I notice lots of small paint chips and small scratches because of minor wheel stick out. They do look great though
Jan 10, 2026 02:16 AM
b2autodesigns
Wheel & Tires
507
Apr 5, 2018 11:38 AM
GW330
Jun 19, 2017 07:24 PM
jk315
Dec 2, 2016 07:35 AM
Alcaponed
Sep 14, 2016 03:37 PM
