Vossen CV7 on an Infiniti G25x
Old Jan 10, 2018 | 07:30 AM
KyruptMF's Avatar
KyruptMF
Im getting a good deal on Vossen CV7 rims
19 x 8.5 +15 and 19 x 10 +20
do you think i will need spacers for this to work?
Old Jan 10, 2018 | 07:45 AM
Snipres's Avatar
Snipres
They should poke out enough, prob too much. Are you lowered?
Old Jan 10, 2018 | 08:08 AM
KyruptMF's Avatar
KyruptMF
im running stock everything at the moment
Old Jan 10, 2018 | 08:10 AM
KyruptMF's Avatar
KyruptMF
the other option is 19 x 10 +38 all around
Old Jan 10, 2018 | 08:48 AM
For a G sedan that top set you listed will be poking like a skateboard. A 19x10+38 will poke less but still about 8-10mm outside the fender on a lowered G and more at stock height. Depends on the look you're going for, but I'd shoot for a set that will get you flush without the poke.
Old Jan 13, 2018 | 12:44 AM
KyruptMF's Avatar
KyruptMF
So i ended up getting a set of Vossen CV3R.
Front: 20 x 9 +32
Rear: 20 x 10.5 +45
I just need to know the size for tires.. im thinking of a 1.5 to 2 inch drop in the near future though.
Old Jan 13, 2018 | 09:24 AM
Front: 20 x 9 +32
Rear: 20 x 10.5 +45
Nice, now that's a sedan-friendly setup! You can run 245 or 255/35/20s front and 275 or 285/30/20 rear. If you aren't going to be lowered for a while I'd run the 245/35 & 275/30 combo.
Old Jan 13, 2018 | 11:13 AM
KyruptMF's Avatar
KyruptMF
Awesome thanks. I was kind of leaning to that tire width already, just wasnt sure if i should run 30 and 30 or 30 and 35.
Old Jan 13, 2018 | 02:02 PM
With a staggered setup you almost always want to run a series smaller in back to keep diameters similar, so the 35 front 30 rear for the win!
Old Jan 14, 2018 | 01:43 AM
KyruptMF's Avatar
KyruptMF
Thank youu
SabanBec
Feb 6, 2018 05:38 PM
Scotch
Dec 6, 2017 04:44 PM
Scotch
Dec 6, 2017 04:40 PM
SeanM93
Apr 27, 2017 09:20 AM
jarborn1
Wheel & Tires
93
Dec 2, 2009 10:58 AM
