245/45R17 Vibes
Old Dec 1, 2017 | 05:42 PM
jh.'s Avatar
jh.
245/45R17 Vibes
Just got back from a drive on a windy road and am finally ready to admit defeat.
Installed 245/45s on my 17” wheels (09 x) a few weeks back. Tires are loud (sumituomo) but I get what I pay for. They’re very grippy in wet conditions so that’s nice. Also had existing spacers - can’t remember what size - probably 1/2” or 3/4”.
But when I turn the wheel right, I rub. I can not replicate it in my garage and cannot see an area even remotely close to touching the tires when parked and turning the wheel.
But on the highway, even 1/4 turn of the wheel and the noise is deafening. I’m at a loss. Any suggestions?
Old Dec 2, 2017 | 09:15 AM
Is your G lowered? Interesting that it's only when you turn it right. Any pics you can provide might help.
Old Dec 2, 2017 | 11:05 AM
stealthee's Avatar
stealthee
Have you checked the rear tires? It could be weight transfer, hence why you can't see anything or replicate it in your garage.
Old Dec 3, 2017 | 02:18 PM
jh.'s Avatar
jh.
Is your G lowered?
It is not lowered.
Agreed...it makes me wonder if a bushing or suspension component on the left side is tired (115k miles).
Not sure what to take pics of...there is nothing noticeable upon inspection...
I had not thought of this, and it's a great suggestion. I ran my arms completely around both rear tires - focusing on the left rear - and found no areas that would potentially rub. Again leading me to wonder if the rear left suspension components are just tired and under weight transfer, there is rubbing.
I do not see any obvious damage to any of the tires...so while that's great - it doesn't help me diagnose the issue.
Old Jan 6, 2018 | 04:17 PM
jh.'s Avatar
jh.
Could a tired rack & pinion be causing a vibration in one wheel position only?
Old Feb 18, 2018 | 02:16 PM
jh.'s Avatar
jh.
Problem solved. Wheel bearing. Never had one go bad, so I didn't know what I was hearing. Super easy replacement on the G. Good as new now.
Old Feb 18, 2018 | 02:59 PM
slartibartfast's Avatar
slartibartfast
Thanks for reporting your solution.
Old Feb 18, 2018 | 03:00 PM
Good to hear (or not hear anymore, lol) I would consider 245/50/17s next tire time though, the 245/45/17s are about an inch shorter than oem diameter.
Old Feb 20, 2018 | 06:06 PM
jh.'s Avatar
jh.
The speedo being off (quite considerably at speed - 90mph = 86mph) is frustrating, but I do like the lower profile. At some point during the summer, I think I will add new suspension components to lower her a bit.
Thanks all!
Old Apr 10, 2018 | 01:00 AM
infinistic's Avatar
infinistic
Thanks all!
Could 245/50/17 fit on oem 17" rims? Would wider tires give dull turn in feeling?
Old Apr 10, 2018 | 02:07 AM
slartibartfast
As I wrote in your other post (spamming multiple forums with one question is bad form), 245 is a but too wide for the 17s.
Old Apr 10, 2018 | 10:38 AM
infinistic's Avatar
infinistic
Spamming multiple threads was not my intention for sure. I thought I would ask again in a more recent thread after noticing that the previous thread was updated in 2011 the last time.
I found another thread with more details about my question
https://www.myg37.com/forums/g37-sed...estions-3.html
Thanks!
Old Apr 10, 2018 | 01:07 PM
My reply in that last thread you linked wasn't real precise when I said a 255 on a 7.5" would be a standard mount, the recommended wheel width range for a 255/50/17 for one tire example in the tirerack listings lists a 7-9" range for the first tire in this list (click on specs)
https://tires.tirerack.com/tires/255%2050%2017
So that said, the 7" would be a pinch mount IMO, and the 9" would be just a bit more than standard. The taller sidewalls of a 50 or 55 series make the stretch or pinch seem less dramatic vs. the short sidewall 35-45 series that are more common with that width tire (on the 18-20" wheel sizes).
Old Apr 10, 2018 | 01:35 PM
infinistic's Avatar
infinistic
I hope I'm not spamming this thread.
Thanks for correcting my info as I'm still surfing the forum collecting info and getting to know what others' experience are with 245/50/17 on stock 17"
So your reply in this thread is not accurate too?
https://www.myg37.com/forums/wheels-...-17-tires.html
Old Apr 10, 2018 | 01:39 PM
Reply was accurate as far as being in the manufacturers recommended wheel width range, but I just wanted to being a little more definitive regarding what would be considered a pinch mount, which IMO a 255 on a 17x7.5 would be on the borderline of.
