xs Coupe - staggered question
Old Jul 22, 2016 | 01:44 PM
Alto101's Avatar
Alto101
I have another thread seeking input on a set of wheels for my xs coupe, see:
https://www.myg37.com/forums/wheels-...eel-specs.html
A separate question - for those who have switched from a square to a staggered setup, what handling changes have you noticed? I believe that going with a wider tire in the rear, the grip in wet may suffer but dry handling will improve? Any thoughts?
Thanks!
Old Jul 22, 2016 | 02:15 PM
Kris9884's Avatar
Kris9884
Thanks!
I don't see how a wider tire would hinder the wet grip unless you went with a more performance oriented tire instead of an all season. More tire on the ground almost always means more grip.
Old Jul 22, 2016 | 02:41 PM
Alto101's Avatar
Alto101
That was my thought as well. There seems to be some debate though which surprised me - see:
Are wider tires more susceptible to hydroplaning? - Straight Dope Message Board
I know with snow tires you want narrower which makes sense to me. I always thought you would want wider in the rain though.
Thanks
Old Jul 22, 2016 | 02:46 PM
Kris9884's Avatar
Kris9884
Thanks
Interesting points of view to say the least.. From what I got out of all of that is wider is still better, as long as the tread has plenty of area for the water to run through.
Old Jul 22, 2016 | 03:09 PM
VenomGT9's Avatar
VenomGT9
The understeer will be more noticeable than the changes in grip.
If you have adjustable sways, knock the front up a notch and you'll be fine.
Old Jul 22, 2016 | 04:10 PM
Also wider tires are more prone to tramlining, especially going wider in front, so if you drive on a lot of grooved roads it's something to keep in mind.
pal51961
Apr 4, 2016 07:50 PM
sptl99
Mar 19, 2016 06:48 PM
