Help Wheel adapters
Old May 30, 2016 | 10:52 AM
Redfire32's Avatar
Redfire32
Ginger ninja
Wheel adapters
Anyone have experience with wheel adapters???
I got the wife a new Audi Q5 and I want to put my spare Vossen CV4's on it.
But the bolt patterns are different.
I need a 5x112 to 5x114.3 adapter, but it cannot be too thick BC the Vossens are 20x10.5" squared so I want to minimize wheel poke and make them as flush as possible.
Something like .5" or .75" thickness would be preferable.
Old May 30, 2016 | 12:46 PM
micafd3s's Avatar
micafd3s
thought about using them in the past.. one of the reasons I decided against it was the thickness..
in my case.. even at minimum.. it pushed the wheel too far out causing clearance issues with the fender..
the minimum was the required depth for existing studs to properly mount to..
Old May 30, 2016 | 04:29 PM
As far as their design/reliability, they will perform the same as a bolt-on wheel spacer so as long as the quality is there you'll be fine. Not sure the minimum thickness available, probably 15mm I'm guessing. There might also be a problem finding them w/ the correct hubcentric specs.
Old May 30, 2016 | 05:00 PM
micafd3s's Avatar
micafd3s
id tend to think for the g that it would at least need to be 25mm...
Old May 31, 2016 | 01:36 PM
Mattimus's Avatar
Mattimus
I've been running 19mm adapters from Motorsport-Tech for about two years now (Porsche wheels) and have had zero issues. Their website shows a minimum thickness of 15mm for hubcentric adapters.
Old Jun 3, 2016 | 07:38 AM
Redfire32's Avatar
Redfire32
Ginger ninja
Thanks fellas!
Hey guess who found and put $2000 deposit down on a new G vert this am??
THIS GUY ��������
Old Jun 3, 2016 | 07:46 AM
micafd3s's Avatar
micafd3s
congrats... right back up on the saddle eh..
Old Jun 3, 2016 | 10:32 AM
That Dude's Avatar
That Dude
You can run thin adaptors on the Q5 because they don't have lugs, they use lug bolts. So preferably you would want a adaptor that converted to 5x112 lugs. If you can find them, they will be as thin as 10mm.
Furthermore, you can try wobble bolts because 5x112 and 5x114.3 are very close. My boy ran 5x114.3 wheels on his A4 with wobble bolts. No need for adaptors.
Old Jul 24, 2016 | 11:38 AM
Project-vipg's Avatar
Project-vipg
You studs didn't stick out through the adapter at 19mm? Also can you use your original lug nuts adapter to Hun or do you need special small one the pictures make it hard to tell.
Old Jul 25, 2016 | 04:52 PM
Mattimus's Avatar
Mattimus
The stock studs stuck out just a little bit. I cut off about an 1/8" and still had plenty of threads for when I temporarily switched to GTR wheels. This might not be needed if your wheels have pockets on the backside of the mounting surface. The adapter came with nuts to bolt it to the stock hub. I hear they make low profile nuts for the smaller adapters now. Overall it was a simple bolt-on situation. Just make sure to follow the torque instructions.
2012G37
Jun 14, 2016 12:27 AM
steve_ipl
May 23, 2016 11:30 AM
300ZXTT
May 6, 2016 09:20 PM
devin156
May 4, 2016 06:07 PM
pal51961
Apr 4, 2016 07:50 PM
