HELP! Do these wheels fit my car?
Old Apr 6, 2016 | 08:54 PM
al3cks's Avatar
al3cks
Hey guys, I recently got a 2013 Infiniti G37s Coupe and looking to get the Velgen VMB7 wheels.
Dealer said they have the following figment available:
20x10.5 5x114.3 45et
I was hoping someone could tell me if this would fit my car?
If not what size would you recommend?
Any feedback would be appreciated. Thanks!
Attached Thumbnails HELP! Do these wheels fit my car?-image.jpeg   HELP! Do these wheels fit my car?-image.png
Old Apr 6, 2016 | 09:01 PM
VenomGT9's Avatar
VenomGT9
Given the lack of info and obvious searching capabilities, you want to run that size as a square fitment?
If so, you may need some work to get those to fit in the front...camber will be a factor.
For the rear, those will be fine just choose your tires wisely...275/30 area
Old Apr 7, 2016 | 12:11 AM
Front may have trouble w/ inside clearance, that much positive offset on a 10.5 may contact the steering knuckle up top. There are some coupes running 10.5 square , but with offsets in the +25 to +30 range. Check this thread for more pics/info. There's a coupe on page 8 member "Simpson" that should be of interest
https://www.myg37.com/forums/brakes-...post-here.html
Old Apr 7, 2016 | 12:58 AM
Damn a 20x10.5 +45 offset in the front? I have that exact size in my rear with 275/30/20 tires with no issues. Are you sure that's the same size and offset all around for the front and rear? I'd double check and make sure it's not a staggered setup where the rears are wider then the fronts.
Old Apr 7, 2016 | 01:27 AM
ZOSTER33's Avatar
ZOSTER33
Run a spacer up front if you really want to run that particular setup.
Old Apr 29, 2016 | 09:31 AM
al3cks's Avatar
al3cks
Thanks for all the feedback guys. I've decided to run 20x9 front and 20x10.5 rear. Put a hold on getting wheels but will post a picture once I decide to get a set.
Old Apr 29, 2016 | 10:06 AM
VenomGT9's Avatar
VenomGT9
If you're set on those sizes, you can look into a set of GTR wheels.
They'll cost the same as those Velgens but they are of muchhhhh better quality
FS: CBA Wheels Powdercoated GMG. NJ. $1000 OBO - Wheels & Tires - GT-R Life
FS OEM DBA Wheels/Tires/ TPMS Sensors $1500 Lebanon PA - Wheels & Tires - GT-R Life
and my personal favorite
AZ: 2013 Black Edition wheels powder coated bronze - Wheels & Tires - GT-R Life
Need 4 Speed
Wheel & Tires
40
Sep 22, 2016 07:51 PM
OfficialG
Mar 30, 2016 10:15 PM
armino41
Mar 30, 2016 01:25 PM
chee37
Mar 24, 2016 04:34 PM
Weedy38
Mar 24, 2016 02:56 PM
