Work Wheels Tarnished! Need Help!
Old Mar 19, 2016 | 11:38 AM
  #31
Broski28's Avatar
Broski28
Im with Vizard. I'm not sure what color you should go with but damn did they look good before!!!
Old Mar 19, 2016 | 03:05 PM
  #32
jacob sami's Avatar
jacob sami
Originally Posted by beachbum718
Damn 200 a wheel.where i live they will poweder coat wheels for 400.and that includes 3 pc wheels taken apart and resealed.word of the wise dont buy work wheels.if you do stick to polished lips.that way you can always make them look new again.and if you curb them .you can fix them 123 with a dremel kit.400 grit then 1500.then 2000. then 0000 wool.then mother's.polish.
I personally ,dont ever buy color rims or chrome.straight polished.otherwise.something happens and its an arm and leg to fix them.besides,polish lips bling.for 800 you probably could of sold your rims threw the 800 on top your sale.BAM.new wheels....my two cents
Im keeping them the same color, and i would agree to sell them and all but i waited 3 and half months for these to come, the other option wqas some nice SSR's, ill stick with them for now. i called up the rim shop and asked how is it going, and they said they might be done Monday, they said they spend hours making sure they are 100% perfect and that they want to take their time, and i said no problem of course as long as they are done right. I learned my lesson on wheel period! hopefully this thread helps others!
Originally Posted by dessidee90
I'm from BR too, I knew that picture you took on Florida, looked kinda familiar haha! Sorry to hear about your wheels man hopefully you get it sorted REASONABLY and soon.
Bruh, we can be like best friends lol, i saw a few G's locally but it will be nice to make a G/Q meetup or something!
Thanks, Im keeping them as is, just repairing the marks that fool did. stay tuned
Old Mar 19, 2016 | 06:47 PM
  #33
Broski28's Avatar
Broski28
Sweet!! That's good to hear you found a solution. It would have almost hurt to see such a beautiful finish powder coated.
Btw do you have the full IPL kit? I can tell by the F and R bumpers but I wasn't sure about the skirts
Old Mar 19, 2016 | 07:07 PM
  #34
jacob sami's Avatar
jacob sami
Yes i got the whole Kit, Front, Rear and sides, i ordered them from Sergio threw this dealer in Cali, he is somewhere on the forums lol, all parts came in painted with everything needed, it was easy pop i parts.
Old Mar 19, 2016 | 07:50 PM
  #35
ZOSTER33's Avatar
ZOSTER33
I found some pics of my damaged finish. These are the barrels. The step lips are also damaged but not as bad as the inside.
Old Mar 20, 2016 | 10:51 AM
  #36
jacob sami's Avatar
jacob sami
Man those are worse than mine , what did they use?!?! at least i had spots, but the guy cleaned my car before using the same stuff he said, he would use it clean, dry, and even use a vacuum to suck the remaining water, but my wheel design allows for water to hold in between the spokes and the barrel, and with it sitting out side the started to drain down to one spot, but the shop is also doing the inside barrels for me , $200 per wheel is a lot but these are not your average wheels. freaking pricey wheels!!
Old Mar 20, 2016 | 03:21 PM
  #37
ZOSTER33's Avatar
ZOSTER33
They used some kind of degreaser on them. The owner had his workers hand polish them and they came out okay but knowing that the original finish has been damaged really irks me.
Old Mar 20, 2016 | 06:26 PM
  #38
guy from norcal's Avatar
guy from norcal
I found some 3000 grit sand paper at autozone it's actually a sponge with grit. I used that just before polishing with mothers. I would give that a try on your lips then polish. You definatly cant hurt it anymore than it is with such a fine grit.
UNLESS YOU HAVE A CLEAR COAT ON THEM. then it won't work.
Old Mar 20, 2016 | 09:10 PM
  #39
ZOSTER33's Avatar
ZOSTER33
[QUOTE=guy from norcal;4008660]I found some 3000 grit sand paper at autozone it's actually a sponge with grit. I used that just before polishing with mothers. I would give that a try on your lips then polish. You definatly cant hurt it anymore than it is with such a fine grit.
I can't do that. I have a brushed finish to it
Old Mar 21, 2016 | 01:58 AM
  #40
I really am so sorry this happened to you I'd go nuts man
Old Mar 21, 2016 | 08:44 AM
  #41
ChinkyChoy's Avatar
ChinkyChoy
I thought Work and Volk wheels come with a clear coat on them
Old Mar 21, 2016 | 12:03 PM
  #42
quakerroatmeal's Avatar
quakerroatmeal
Just let the pro's take care of it.
Old Mar 21, 2016 | 01:09 PM
  #43
jacob sami's Avatar
jacob sami
im wondering if they bring back the polish the wheels back would they need a clear coating? i don't know if mine had a clear coat or not, my wheels should be done today or tomorrow we will see.
Old Mar 21, 2016 | 06:18 PM
  #44
guy from norcal
Probably not. Just means you have to give them a quick polish once every month or so. Depending on weather situations.
I stripped the clear coat off of my wheels. But my lip doesn't have the spoke covering it either.
Old Mar 21, 2016 | 06:30 PM
  #45
ZOSTER33's Avatar
ZOSTER33
If it had a clear coat on the inside barrell the acid or whatever the used ate through it. The step lip has stains on them but not that shade of blue like the barrells.
