Rim Diameter Difference on a 37x
Old Nov 1, 2015 | 03:17 PM
SurreyG's Avatar
SurreyG
If I did purchase a set of staggered rims for my G37x should I be worried if the fronts are 8.5" and rears are 10"?
Can I put rubber on these that will work? Or will the rim diameter difference alone cause the AWD sensors to go all crazy on me.
Thanks.
Old Nov 1, 2015 | 03:41 PM
Thanks.
I assume you meant rim width rather than diameter, unless the fronts are 18s and the rears are 19s for example. As long as you have offsets that will allow you to run compatible tire sizes they will work ok. One example for 19s would be a 245/40/19 & 285/35/19 set, this results in about 0.5% variance.
Use this calculator whenever trying new combos, for your AWD you want as close to zero variance as possible and no greater than 1% difference.
Old Nov 1, 2015 | 04:03 PM
RxRyanM's Avatar
RxRyanM
Brad, you might actually want to link the calculator next time
Old Nov 1, 2015 | 05:29 PM
SurreyG's Avatar
SurreyG
Thanks Brad yeah meant Rim width, Fronts are 20 x 8.5"
Rears are 20 X 10"
Just want a tire size and rim setup that won't throw off the AWD.
Old Nov 1, 2015 | 05:50 PM
the_wolff's Avatar
the_wolff
I don't understand why you'd want different sizes on AWD. With AWD on a car that favors RWD, you're going to want to rotate the tires for longevity. What are you hoping to gain, and is it worth replacing tires more frequently?
Old Nov 1, 2015 | 07:06 PM
SurreyG's Avatar
SurreyG
Good point only I drive so little mileage wise that it wouldn't be a big deal.
Old Nov 1, 2015 | 07:26 PM
Rears are 20 X 10"
On 20s you have two choices that are both a very minimal 0.07% variance.
235/35/20 & 275/30/20 OR 245/35/20 & 285/30/20.
I have the 2nd combo on my RWD G, my offsets are 8.5 +40 and 10 +45. What offsets are offered w/ the wheels you want?
Old Nov 2, 2015 | 09:32 AM
SurreyG's Avatar
SurreyG
The 8.5 are +32 and 10" are +35.
Old Nov 2, 2015 | 10:53 AM
You'll have to run a narrower combo since the backs are a +35. A 225/35/20 front 265/30/20 rear will fit and only have a 0.23% variance, and the rear is slightly taller (which is ideal since they wear faster so the variance will improve over time).
If you run a 275 in back it will be too close to the fender and may require running heavy camber to clear.
ChinkyChoy
Oct 20, 2016 02:20 PM
parkern
Jan 4, 2016 02:33 PM
Topher9425
Nov 18, 2015 08:18 PM
JohnnyS
Nov 1, 2015 12:35 PM
the_wolff
Oct 30, 2015 07:10 PM
