Help don't want staggered tires
Old Oct 28, 2015 | 09:15 PM
Rsworden's Avatar
Rsworden
Have a 2012 g37s coupe. Was wondering if I can run 245/40/19's on the front and back and loose the stagger, I'd like to be able to rotate tires. I have the stock wheels. Thanks.
Old Oct 28, 2015 | 11:24 PM
No. The wheels are wider in back than up front. To do what you want, you need to have all 4 wheels the same size. You can trade or buy a pair to get a set of 4 same sized wheels. Then you can do it.
Old Oct 28, 2015 | 11:29 PM
beachbum718's Avatar
beachbum718
You can use the same size tires.and have a shop flip the tires themselves around from front to back side to side.where i live.its 20 a tire mounted and balanced.pretty cheap.so 80 plus a tip to rotate tires off the rims not just entire rim and tire...i run camber and get camber wear.so i flip my tires inside out.to prolong my cambered tires.Goodluck
Old Oct 30, 2015 | 05:03 PM
Neal@tirerack's Avatar
Neal@tirerack
MYG37.COM Platinum Sponsor
The front wheels are 19x8.5 and rears 19x9's. A 245/40-19 will fit wheels 8" - 9.5" wide so you'll be fine, but cant rotate due to the stagg wheel sizes. That's a pretty common tires size upgrade.
Old Oct 30, 2015 | 07:59 PM
I did the whole rotating single sized tires on staggered fitment wheels thing before. I had 350Z wheels on my old Maxima. It is a pain in the a** and will cost you about $100 each time you rotate them. If you rotate them every 5-7K miles, you could just buy 2 sets of rears for every set of fronts you wear out and still come out ahead. Not to mention that the tire shop WILL scratch up your wheels at some point with all the additional mounting/dismounting every time they rotate.
So I guess I should change my statement - you CAN actually do it. But you SHOULDN'T. It will cost you more time, effort, and money than just running staggered and buying more rear tires than fronts.
Old Oct 30, 2015 | 08:05 PM
I guess if you have assymetric tires (the ones w/ OUTSIDE stamped on them) you could at least rotate side to side without having to do a remove/remount. Better than nothing at least
delfinparis
Jun 29, 2022 11:03 PM
delfinparis
Nov 16, 2015 02:26 PM
Murkr
Oct 30, 2015 01:54 PM
viventi
Oct 21, 2015 12:16 PM
si_driver
Oct 15, 2015 10:44 AM
