Problem Attempting To Install Front H&R Trak DRM Spacers
Old Aug 24, 2015 | 11:03 PM
WillCo1's Avatar
WillCo1
Well, I'm getting my KW Coilovers installed tomorrow. I decided to put on my front and rear spacers today.
The rear spacers, 15MM, went on no problem. Looks great. Except car looks more 4X4 than ever.
I attempted to install the fronts (20MM) and as soon as I had the wheel off, I noticed this:
Is this some sort of sensor or something? Doesn't really matter what it is. It's in the way!
What options do I have to still add front spacers? Do I need to get the spacers that require adding longer studs to my front hubs?
Thanks for the help.
Old Aug 24, 2015 | 11:27 PM
WillCo1's Avatar
WillCo1
Well after searching Google even more, I found a thread on G35driver.com .
DIY: Ichiba V2 Wheel Spacer Installation - G35Driver
Apparently this is whats known as a dummy bolt/stud. It's purpose is so a moron doesn't accidentally install the rear wheels on the front.
This is a relief. Unfortunately it is already dark and I will need to get dirty again tomorrow.
Remember, Google is your friend.
I just can't believe I have never noticed the dummy stud until now. I have even had to change the front tire a couple of times.
Old Aug 25, 2015 | 12:12 AM
iGGy37S's Avatar
iGGy37S
Here is another thing you should be aware of - stock setup is slightly pushed into the wheelwell, on any car, which always casts a shadow on top of the tire. It gives you the illusion of being lower because the shadow hides the gap to a certain extent.
When you push wheels out with spacers or a wider setup in general the shadow is no longer there, so you have to go lower to fill in the gap to a level you find appealing.
Old Aug 25, 2015 | 12:55 AM
WillCo1's Avatar
WillCo1
Yeah, for sure. When I looked at the rear after I removed the jack stands and lowered the jack, I was like wtf. So much space from the top of the tire to the bottom of the wheel fender.
I would never want to add wheel spacers to this car unless it is going to be lowered.
Old Aug 25, 2015 | 09:38 AM
PongSanity's Avatar
PongSanity
just take that off. its so the stock rears can't fit on the front "by accident" ... staggered stay staggered... i took mines off and never put them back on.
Old Aug 25, 2015 | 02:25 PM
WillCo1's Avatar
WillCo1
Yeah, already took them off and installed the front spacers. No problems.
Car is getting coilovers installed as we speak.
m3clubracer
Sep 11, 2016 09:01 PM
Thedbarz
33
Feb 9, 2016 12:05 AM
Intake
Dec 25, 2015 09:38 PM
i heart ricers
12
Dec 9, 2015 04:15 AM
