TPMS question
Old Jul 15, 2015 | 10:00 PM
HMG37's Avatar
HMG37
TPMS question
I have an 2012 G37xS Sedan currently, and I have accumulated two sets of TPMS sensors in addition to my stocks. I was wondering if anyone knows the following TPMS are able to work with my car, or should I just sell them.
40700 JK00A
40700 JK00C
Thanks for your help!
Old Jul 18, 2015 | 12:13 AM
HMG37's Avatar
HMG37
Bump!!!!
Old Jul 18, 2015 | 01:24 AM
VIVID's Avatar
VIVID
Pyroclastic Flow
40700 JK00A
40700 JK00C
OEM For 2012 is:
Infiniti > G37 > 2010-2013 (Built on or after 3/20/10) >
2010-2013 INFINITI G37 TPMS Sensor Pacific 407001LA0C
They were very specific about the year of the car. The ones you listed will work on different years.
Infiniti > G37 > 2008-2010 (Built before 3/20/10) >
2008-2010 Infiniti G37 TPMS Sensor Pacific 40700JK00C
I don't know why this is the case. If they are 315 MHZ, one would think they would be programmable. Perhaps they will all work just fine...the reference was just addressing what was OEM and they just changed model for supply reasons.
I'm pretty sure when others buy tires and TPMSs, they don't specify an Infiniti TPMS model number and they program just fine.
Note: you might consider having a moderator move this thread to the wheels and tires section. It will get more specific attention there.
Sean
Old Jul 19, 2015 | 03:36 PM
Bocchia11's Avatar
Bocchia11
Hi maybe someone here can answer this TPMS question I have. I have a 2010 G37XS and last weekend I had my battery drained because I accidentally left the car in the on position. When I got the car jumped, the TPMS light blinks for about 1 minute and stays solid. The air pressure is all good. Does anyone know what I could do? Is there a reset or something? Thanks and appreciate all responses.
Old Jul 19, 2015 | 05:53 PM
telcoman's Avatar
telcoman
Follow steps in the FSM
http://www.nicoclub.com/FSM/G37/Sedan/2011/WT.pdf
Telcoman
Old Jul 20, 2015 | 01:21 AM
JSolo's Avatar
JSolo
Just say no!!!!!
Telcoman
Which procedure you referring to? Page#?
Old Jul 20, 2015 | 10:37 PM
HMG37's Avatar
HMG37
anybody know what year the JK00A TPMS is from?
Old Jul 21, 2015 | 10:25 PM
linusent01's Avatar
linusent01
I think he's referring to page WT-22, section 3:
TRANSMITTER ID REGISTRATION PROCEDURE (WITHOUT TRANSMITTER ACTIVATION TOOL)
Old Jul 21, 2015 | 10:39 PM
JSolo's Avatar
JSolo
Just say no!!!!!
Thanks for the details. I briefly looked through the pdf, but after midnight the brain shuts down. Would of been helpful if the person posting included all the pertinent details. Needless to say the fsm still makes reference to an id registration procedure - 2nd part of step #2 in section 3.
I recall seeing a thread on here about shorting out a particular wire under the dash then setting the pressures similarly. I'll have to see if I have that saved in my bookmarks.
Old Sep 10, 2015 | 12:41 AM
sChiG37xS's Avatar
sChiG37xS
I recently had a tpms swapped out because the valve was bad. Bought it from Autozone and had the same problem. Light blinked for a minute when I started the car then stayed on. I read online that the dealer charges 70-75 to relearn the tpms. I just left it on but then i needed new tires.
Got the tires mounted from Firestone they charged $20 to reset the tpms light because you need the tool for it. Hope that helps!
Old Nov 14, 2017 | 03:20 PM
zonnie's Avatar
zonnie
changed to my oem winter wheels with TPMS and now the TPMS light is on.
called around and dealer wants 75-100 to get it recalibrated. Come spring when i put on my summer wheels i'll have to pay another 75-100 to get it recalibrated again.
any advice? live with the light or anywhere to get it done cheaper?
Old Nov 14, 2017 | 06:05 PM
MH2013's Avatar
MH2013
Try following these relearn steps
https://www.myg37.com/forums/d-i-y-i...-for-free.html
Old Nov 14, 2017 | 06:49 PM
the93owner's Avatar
the93owner
I've learned to live with the light. It's been on for 2 years lol. You kind of just glance over it and soon enough you won't even notice it's there.
Old Nov 15, 2017 | 12:42 AM
Epiphany's Avatar
Epiphany
See if you can get a tire shop to clone the sensors so that both sets of wheels have the same codes for the sensors so there's no re-calibration needed. Amazing that the car can't store multiple sets of codes.
Old Nov 16, 2017 | 11:00 AM
ryanwhite74115's Avatar
ryanwhite74115
NTB and Discount Tire, for me at least, reset my TPMS between winter and summer wheels all the time for free. Basically, if it's a PITA, they charge. Nissan TMPS is easy.
04G35NYC
Dec 24, 2015 01:00 AM
helloandchau
Oct 6, 2015 05:26 PM
Bobo
Oct 1, 2015 10:52 PM
Detailed Image
Lighting/Cleaning Products
Sep 11, 2015 08:33 AM
