2013 G37 Convertible 19 inch on 2013 G37X Sedan
Hi,
sorry to create anoter thread on tire and offset, but I could not find that information anywhere.
I'm still looking for new Wheel for my G37x Sedan 2013 and found something locally. I would like to know if it would fit.
2013 G37 Convertible 19 inch. wint 225-45-19 Front and 245-40-19 Rear.
Tire Size look good I think, but The 9 inch +30 offset is far from the stock + 43
Would they fit?
I think the spec according to this site are:
Front: 19"x8.5". Cast aluminum. Made for Nissan/Infiniti by Enkei. Weight: 26.5 lbs. Bolt pattern 114.3 x 5 Offset +43
Rear: 19"x9". Cast aluminum. Made for Nissan/Infiniti byEnkei. Weight: 27.5 lbs. Bolt pattern 114.3 x 5. Offset +30
Thanks
Would they fit?
Thanks
Only issue would be tire size, you may have issues at higher speeds w/ your AWD since your variance is at 1% with the back tire being smaller in diameter. The rears wear faster so this variance will increase over time. If you go to a 255/40/19 rear your variance will only be 0.22% and the rear will be a bit taller so your variance will improve over time.
Ginger ninja
I've got a set of the wheels your wanting FS with OEM potenzas (7/10 tread depth) and yokohamas (6/10 tread depth). The set only has around 11,500 miles on it. Some curb rash but I'm pricing in fixing costs. Great deal. Text me I'll send you some pics of you like. Just pm me n I'll give you my number.
Thanks for the info, but apparently I'm doomed in my search for new wheels...
It's the second time in a row that I have contacted selle, saw the Wheel and the day I'm suppose to pick them up, The seller choose to keep the Wheel they were supose to sell me.
Back to square one!
Back to square one!
