MAX tire width on 09 37x coupe
Old Apr 14, 2015 | 04:56 PM
CoffaMAN's Avatar
CoffaMAN
Question MAX tire width on 09 37x coupe
Hello everyone!
new to the forum, hopefully posting this thread in the right place.
i want to put summer tires & rims on my '09 G37x coupe. stock is 225/50/18
Basically, i want to upgrade to bring it up to 19" but put a really fat tire on them. how can i find out how much clearance i have in the wheel well?
i was hoping on getting 245/30/19 on the front,
and 275/30/19 on the rear. is this possible? please give me any suggestions or info or tips!
i was advised to put 245/30/19 all around, but i would much rather have a fatter rear tire.
Old Apr 14, 2015 | 04:59 PM
Ryne's Avatar
Ryne
The Steering Wheel Guy
Fattest tire? Probably 305
285's are pretty common around here.
Old Apr 14, 2015 | 05:02 PM
G37xhibeet's Avatar
G37xhibeet
I'm running 245/35/20 and 285/30/20
Old Apr 14, 2015 | 05:04 PM
CoffaMAN's Avatar
CoffaMAN
thanks ryne
285s would be perfect, i just wanted to make sure i wont get any rubbing or run into any other problems.
Old Apr 14, 2015 | 05:51 PM
HoldmyMouse's Avatar
HoldmyMouse
Originally Posted by CoffaMAN
thanks ryne
You need to factor in wheel size and offset to determine if you will rub
And play with the tire calculator if you want staggered size. As long as they are within 3%(?) You should be fine.
Old Apr 14, 2015 | 06:12 PM
Actually w/ an AWD you need to be much closer to zero %, issues arise at speeds over 80mph w/ variance over 1% on a staggered setup. With a RWD a variance up to 3% is OK.
Old Apr 14, 2015 | 07:01 PM
CoffaMAN's Avatar
CoffaMAN
i did check out a few tire calculators, for 285/35/19 i am good, no changes.
for 245/35/19 (front) its 0.7%, so still decent.
how can i figure out the offset? i guess that info will be based on which rim i select?
Old Apr 14, 2015 | 07:09 PM
G37xhibeet's Avatar
G37xhibeet
I don't think your calculation is correct. 245/35 front and 285/35 rear makes the rear 4.105% larger.
245/40 & 285/35 puts your rears at 0.5131% larger
Old Apr 14, 2015 | 07:34 PM
Yep, this is the combo you want
As far as offset, most of the wheels come in a few offsets for every width rim they sell. Some only come in one offset and more expensive rims such as Work & Volks you can specify an exact offset w/ some of their sets.
Offset is very important and will determine what will & won't work. Also if you ever plan to upgrade to a Big Brake Kit (BBK) you'll want rims that will have enough clearance for them too.
Old Apr 14, 2015 | 08:21 PM
CoffaMAN's Avatar
CoffaMAN
thanks! good to know.
i really dont see myself doing any performance upgrades on this at all, unless a simple cold air intake and minor exhaust upgrade, but i really hate to get rid of the stock sound. we also have an IPL in the house, so it just defeats the purpose of me doing any mods on mine. if i want a touch more fun, just jump in the IPL.
Old Apr 16, 2015 | 03:16 AM
Gtdan's Avatar
Gtdan
Make sure since you AWD to run square setup
Old Apr 16, 2015 | 09:29 AM
CoffaMAN's Avatar
CoffaMAN
what do you mean by square setup?
Old Apr 16, 2015 | 02:28 PM
Running all 4 wheels & tires the same size, it's the safest setup for AWDs since different rolling diameters can cause problems for the AWD system, especially at higher speeds.
Old Apr 16, 2015 | 02:41 PM
CoffaMAN's Avatar
CoffaMAN
thanks
this is what i am starting to think now. spent a couple days looking into this and doing some research, and it just seems to complicated, and a few factors that i know nothing about, i dont want to take the risk. hard time finding a set of rims in the sizing that i want too.
at this point im wondering if the front can handle 255, then i will probably just do 255/30/19 all around. comments?
Old Apr 16, 2015 | 04:21 PM
G37xhibeet's Avatar
G37xhibeet
Ryne runs 255/35/20 on all corners so the front can definitely handle that. For 19s I guess 255/40/19 is what you would want.
And just FYI: I, as well as others, run 245/35/20 & 285/30/20 with absolutely no issues.
Full disclosure: I've only gotten the car up to 90 on this setup.
So....square is the safest route, but if you really want the fat rears you can have them
