Anyone running 20x10.5 +30 in the rear? (sedan)
Old Mar 11, 2015 | 09:27 AM
cabo's Avatar
cabo
I wanna go 20x10.5 +30 in the rear I wanna see if anyone is running it. I don't mind a lil stretch!!
Old Mar 11, 2015 | 10:40 AM
Twista's Avatar
Twista
I am just got done lowering it and it fits perfect with the fender
Old Mar 11, 2015 | 11:09 AM
JC-RH's Avatar
JC-RH
^ he said sedan.
I am running 20x10.5 +32 with 245/35/20. I'll post a pic soon.
Old Mar 11, 2015 | 12:48 PM
Ryne's Avatar
Ryne
The Steering Wheel Guy
Oh, wow. Those are super aggressive rear offsets for a sedan. I'd expect stretched tires (245/35) and probably 3+ degrees of negative camber along with very short tire life.
Old Mar 11, 2015 | 02:16 PM
cabo's Avatar
cabo
Originally Posted by JC-RH
^ he said sedan.
Ya post some pics please I have 4x new falken 245/35/20 in the shed..
Old Mar 11, 2015 | 05:57 PM
JC-RH's Avatar
JC-RH
Here are my Work VS-XX
20x9.5 +23 running -3 camber
20x10.5 +32 running -4 camber
Both with great tire wear. Just get the toe right.
Old Mar 11, 2015 | 08:40 PM
Ipp391's Avatar
Ipp391
JC.. What size tires are u running in the front? I'm thinking of doing 20x9.5 +20 square but not sure what size tire will fit.. Looks like ur pretty close with those fronts
Old Mar 11, 2015 | 08:50 PM
JC-RH's Avatar
JC-RH
225/35/20 fronts
and
245/35/20 rears
Old Mar 11, 2015 | 09:00 PM
JC-RH's Avatar
JC-RH
This is me running 20x10.5 +25. Same tire size (245/35/20), but about -4.5 camber.
It was a little too much for me. I personally wouldn't go more aggresive than +30 offset.
Old Mar 11, 2015 | 09:28 PM
Ryne's Avatar
Ryne
Even with spot on toe, -4 degrees of camber is not going to wear normally. It's fine if you are OK with that, but I wouldn't make the OP think that's realistic. That's a ton of camber.
Old Mar 11, 2015 | 10:44 PM
cabo's Avatar
cabo
Any rubbing or rim hitting the fender on big dips?
Old Mar 11, 2015 | 10:59 PM
True that ^^
Old Mar 12, 2015 | 02:36 AM
JC-RH's Avatar
JC-RH
Nope. Absolutely perfect.
This goes to show that you don't need any fancy camber kits in the front. I'm running natural camber of -3 in the front. Offset is fairly aggressive, but the stretched tire prevents it from hitting anything. I did cut away a little bit of the rear fender liner when I was running the 20x10.5 +25. I doubt it would be rubbing now with the +32 if I kept the liner intact.
Old Mar 12, 2015 | 02:37 AM
JC-RH's Avatar
JC-RH
True that ^^
10,000 miles with even wear says otherwise.
Old Mar 12, 2015 | 09:24 AM
You can't have even wear when only part of your tire is hitting the pavement, sorry. If you were driving constant figure 8s putting even pressure on the outer edges of your tires then it would be possible, but daily driving no way.
But glad you're happy w/ your tread wear, if it's working for you that's all that really matters.
