I plan on lowering my g37x this spring myself..how u have yours looks awesome bro..I was a little hesitant to have it lowered because of terrible roads we have here in Connecticut but after how u got yours sitting, I need that!!!
I'm running a 10.5 +34, 275/30/20 -2.5 camber in the rear with no issues. My front rubs a bit. I need to revamp my setup when i get it back from getting my air done.
Going with the 275, you will have to roll and pull your fenders, 255 i think you may be able to get away with it as the tire will have a lot of stretch on it.
Originally Posted by cabo
20x10.5 +35 on 255/35/20 or 275/30/20 all around which would be best. I want to seat nice and flush no rubbing
that depends on the design of the wheel.
i had Stance SC-5 and they did not, i had to add a spacer, switched to Avant-Garde 310 and they clear just fine
basically the concave ones will not
im going to order akebono brakes tomorow 10.5 +35 clears brakes?
That isn't true about the 275 (for the rears at least). I've got the exact same setup with a +37 in the rear on 275/30/20 running a -2.4 camber, with room to spare. Front's he may want to run a bigger tire as that is a lot of meat up front.
You are running a different offset and a lot of negative camber.
the rolling of the fender i was referring to lets you sit without any negative camber.
if OP is willing to have negative camber, then he can run 285 or even 295.
Gotcha. Yes that is true. I don't even think I know what OEM camber specs are. It's around -1 right?
