Aftermarket Wheels - Anyone running Square Setup?
Old Apr 5, 2016 | 10:41 AM
Ozzie069's Avatar
Ozzie069
A 10+35 will limit what you can run since it will already be tight at the fender. And yes, you will want to lower your G as 20s don't look great at stock height.
If you don't want to do any fender mods a 255/35/20 all around is about as wide as you could run, and even then you may rub on the inside front fender under heavy compression. You'll be ok in back w/ those though.
So should I run smaller in the front or I'll be ok like that is only going to be a 1.5 drop
Old Apr 5, 2016 | 07:45 PM
What you might want to do is just get a pair of 255s and mount them up, then do a test fit in front to see if you like how they fit, TBH I wouldn't run a narrower tire on a 10" rim, it's been done but I wouldn't do it. If the 255s fit ok but may make contact on that front inner fender edge you could get that edge flat rolled like your rear fender. I think I would do that before running stretched 245s in front.
news1213
Dec 16, 2015 11:06 AM
dAgent
Dec 1, 2015 09:03 PM
Hiryuu
Aug 7, 2015 07:08 PM
