No Rub - Tire Size ??
Old Nov 6, 2014 | 04:08 PM
ay37's Avatar
ay37
Hello. I have a 2012 G37x Sedan (AWD) with 225/55/17's.
I just purchased a set of 19x8.5 str 607's.
Here are my tire options:
225/45/19
235/40/19
245/40/19
I know 225/45 and 235/40 will work, but 245/40/19 gives me the closest diameter to my stock wheels which are 225/55/17.
My question is... does anyone know if 245/40/19's will rub in the front when turning? No drop on this ride either... Just wanna know if anyone here knows if that size will rub when I cut the wheel one way or another..
Thanks
EDIT: forgot to mention that the 19x8.5 str's have a 35mm offset.
Old Nov 6, 2014 | 05:23 PM
ChinkyChoy's Avatar
ChinkyChoy
I have a sedan AWD and I m running 19x9.5 +25 but I used to run 19x9.5 +35
both set ups I had 245/40 and I never experienced any rubbing
I am also dropped on BCs.
hope this helps
Old Nov 6, 2014 | 07:57 PM
ay37's Avatar
ay37
hope this helps
Perfect! I'll take your word for it... hope it works out alright. If you were running 245/40 19x9.5 with +35 offset with no rub, then I should be just fine.
Thanks for the reply
Mattlorentzoe
May 24, 2021 08:49 PM
jayrdong
Oct 25, 2015 10:00 PM
connoisseurr
Sep 20, 2015 04:14 PM
Hiryuu
Aug 7, 2015 07:08 PM
Rubyq60
Aug 3, 2015 10:36 PM
