Need help with Tire Size 18 Inch
Old Sep 26, 2014 | 10:43 PM
strictlys's Avatar
strictlys
I have new wheels
18x8.5 +44
18x9.5 +38
I currently have 19's on my sedan base
19x8.5 245-40-19
19x9.5 275-40-19
I love the 19's, but I am test fitting these new Tires called Driveguard.
Before anyone starts asking questions I don't know. How it rides or whatever.
That is why I am test fitting them and reducing my wheel size to 18 inch to use a stagger fitment to try them out.
Unfortunately Bridgestone has limited sizes.
What would be the best option to put these tires on my wheels?
I was thinking 235/45/18 and 255/40/18
Yes, I need to make any of these Bridgestone Drive Guard sizes fit my wheels.
Would this throw off my speedo alot?
My original size was 225-55-17
http://www.tirerack.com/tires/tires....RFT&tab=Specs#
Old Sep 27, 2014 | 12:02 AM
The following combos will work, hopefully one set will be available from the following~
235/50/18 & 255/45/18
245/45/18 & 275/40/18 (265/40/18 will work in back but be about 1% smaller in diameter)
255/45/18 & 285/40/18
245/45/18 & 275/40/18 would be the best setup if they make those sizes.
You'll probably want spacers in front to get the same fitment as in the back.
Old Sep 27, 2014 | 12:06 AM
It appears only the top pair is available so for your fit I'd go
Old Sep 27, 2014 | 07:05 PM
strictlys's Avatar
strictlys
Yeah, I figure that was the best way to go since its the closest to diameter.
The problem is bridgestone doesn't make a 235/50/18
I was thinking more of
225/50/18
and 255/45/18
Nevermind For some reason it wasn't showing up, but I do see the combo
Thanks for your help.
I hope the test fitting will work for me if not I'm going back to 245/45/18 & 275/40/18 Conti DWS or try out the Michelin AS3's.
Based on the specs I think the 225 might be too small for the 8.5 wheel. I am hoping the 255/45/18 isn't too small.
I am not a fan of stretch tires.
Old Sep 27, 2014 | 08:16 PM
225/50/18
and 255/45/18
Yes, the 225 is too narrow for the 8.5" and the 255 is OK for the 9.5.
Here's a good calculator for rim width, scroll about 3/4ths down and a little single line calculator titled "An ideal Rim Width Calculator" is a nice tool
Car Bibles : The Wheel and Tyre Bible Page 4 of 4
Old Sep 30, 2014 | 07:09 PM
strictlys's Avatar
strictlys
yeah the size worked out great.
Old Sep 30, 2014 | 11:43 PM
Glad you're happy w/ them
Mattlorentzoe
May 24, 2021 08:49 PM
jayrdong
Oct 25, 2015 10:00 PM
connoisseurr
Sep 20, 2015 04:14 PM
Hiryuu
Aug 7, 2015 07:08 PM
Rubyq60
Aug 3, 2015 10:36 PM
