TPMS question
Old Sep 6, 2014 | 06:27 PM
akaG's Avatar
akaG
TPMS question
I haven't been able to find the actual tire pressure read-out on my 2013 coupe.
Old Sep 6, 2014 | 06:48 PM
Dough1397's Avatar
Dough1397
The TPMS system in this car does not display actual readings on any of the displays. It will only alert you if a tire drops below a threshold pressure.
Old Sep 6, 2014 | 07:16 PM
akaG's Avatar
akaG
Thanks. Seems like an easy thing to do considering all the power in that dashboard.
Old Sep 7, 2014 | 05:54 PM
telcoman's Avatar
telcoman
I wish it did but it saved by butt while driving home from work last week at about 70MPH
I heard an auduble blip with a warning light and a lit TPMS on the dash.
Fortunately I carry a tire pressure gauge and pulled over to check the tires.
The drivers side front only had 20 lbs of air. Drove to the nearest gas station and filled the tire with 50lbs.
Made it home to a local tire repair where the pulled this out
Some people ignore the TPMS light but it sure saved my a$s
Glad I didn't have to change a tire.
Telcoman
Old Sep 7, 2014 | 06:20 PM
Telcoman
Damn, nice little slug in that tire
TPMS w/ low profile tires is a real plus as well, very tough to visually notice a big drop in pressure.
Old Sep 7, 2014 | 08:51 PM
JT2014's Avatar
JT2014
Even at 20psi a car is perfectly drivable at reduced speed.. My previous car had the tire readouts. That was very useful. I had it go off a week after I got my G. Screw in tire, but my gauge still read 26PSI.
Old Sep 8, 2014 | 04:30 AM
telcoman's Avatar
telcoman
You don't want to drive 20 MPH on the Parkway and Turnpike in NJ.
Old Sep 8, 2014 | 07:52 AM
JT2014's Avatar
JT2014
I have & will..... ok it was 30 not 20....lol
Old Sep 8, 2014 | 11:25 AM
Dough1397's Avatar
Dough1397
I don't think much of the TPMS system in our cars. It has never actually alerted me to low pressures. When I purchased my car, the fronts were at 28-30 psi and I experience serious tram lining in ruts on the road. This made for a very weird pull when changing lanes on a highway. After a week I checked the tire pressures and found they were both very low (28-30 is much lower than the recommended 35), corrected the issue and my tram lining issues were gone.
Another time, whilst driving home on a cool night, the warning buzzer chimed and the light went on. I pulled over and inspected all my tires, visually they were fine. I pulled out my tire pressure gauge and they all measured close to 36-37 psi. This made sense as I keep them at 35 when cool and I had driven a 20-30km. I went home, parked, checked again in the morning and the light was still on and all tires were at 35psi. This was late fall, a few days later I swapped over to my winters (I don't run TPMS in the winter). Light stayed on all winter. Come spring when I put my summers back on the light had disappeared.
Old Oct 9, 2014 | 11:31 AM
Mr Infinit's Avatar
Mr Infinit
Personally i think the TPMS is BS/useless.. How good is a TPMS if it doesnt tell you which tire is low....WTF INFINITI!!!!
All my tires are at 31psi and my light is now on.. So now its a freakin game to see which sensor is out!!!
Can we install aftermarket sensors? Will they have to be sync'd with the system somehow after installation?
any input is appreciated..
Old Oct 9, 2014 | 01:02 PM
Chekov's Avatar
Chekov
Senior Citizen
I’m afraid you’re missing the point. The system tells you that a tire is low, perhaps at a dangerous level. A $10 tire gauge will tell you which tire that is. That information, albeit not as specific as you would like, is meant for you to take some action before you get killed from a spontaneous blowout.
If you have a sensor out then just get it replaced. However 31psi where 35 is recommended may be low enough to turn on the light. I don’t know if aftermarket sensors would do you any good in your case. But if the lack of TPMS telling you which tire is low bothers you that much, trade up to an Infiniti M, as they do come with that feature.
Old Oct 9, 2014 | 01:46 PM
GAWD's Avatar
GAWD
Valid points. But, the already G knows exactly which sensor is at which corner. It knows the pressure of each sensor. When you rotate your tires, it knows. What Mr. Infiniti was saying, I agree with - the PSI should be readable from the dash menus. The feature is there for the car and mechanic to know, so why hide it from the driver? It would be a $0.00 tech upgrade if the marketing people weren't asleep at the wheel.
Old Oct 9, 2014 | 01:48 PM
Mr Infinit's Avatar
Mr Infinit
Yea, maybe 31 may be low. (i have a $5 tire gauge) I was ranting as this is the first car i've had with TPMS. I am used to checking pressure the old school way. I understand the importance. I also know the stealership will rape me for $$$ to get a new sensor. I was curious if we could buy a sensor from some place other than the stealership?
FYI, my dealer wants $90 for one sensor!!!!!!!!
Old Oct 9, 2014 | 05:05 PM
Black_G37S's Avatar
Black_G37S
Yes, you can buy one sensor as long as you know exactly the date of your car was made.
Remember G37 coupes made in March 2010 and newer have different sensors from the coupes made in February 2010 and older. Those sensors are not exchangeable. This also applies to after market sensors as well.
I bought a set of sensors from Discounted Wheel Warehouse for my summer tire set and they work perfectly. Now I can switch back and forth between summer and winter tire sets without worrying the TPMS light on. There's DIY how to reset/learn your TPMS in the forum and it's easy to follow.
https://www.myg37.com/forums/d-i-y-i...-for-free.html
Old Oct 10, 2014 | 09:20 AM
Mr Infinit's Avatar
Mr Infinit
31psi is a lil too low. I bought pressure up to 33psi, light went out!!
I do have to figure out the manufacture date on my G.. How does one figure that out??
