Noob Tire/Wheel question
Old Aug 1, 2014 | 03:10 PM
Angus_A2's Avatar
Angus_A2
Hi Everyone!
I just bought my 2008 G37S in June...and I love it! I have been exploring this site, though and the strong recommendation of G37S owners, from what I can gather, is that snow tires are an essential, especially since I live in Michigan.
My vehicle has the staggered wheel setup (front 225/45/19 and rear 245/40/19).
I have found a used set of Blizzak LM tires (Front tires: 225/40/19
Rear tires: 265/35/19). Will these fit on my stock wheels??
The seller also has stock wheels (Front wheel sizes: 19" x 8.0"
Rear wheels sizes: 19" x 9.5". The offset is 41mm Front & 27mm Rear)
Any chance these would fit? Or should I just try to buy the tires?
Thank you in advance for any help!!
Old Aug 1, 2014 | 03:14 PM
GoFightNguyen's Avatar
GoFightNguyen
Because Racecar
The stock wheels you mentioned are sedan offsets. If you have a sedan, cool, if you have a coupe, they'll be sunken in. The tires you mentioned should fit, but I'm no expert
Old Aug 1, 2014 | 07:13 PM
Are you sure the rears have that +27 offset?
Infiniti coupe OEMs should have the specs listed on this link
2008 through 2013 Infiniti G37 Coupe Rim and Tire Specifications, weight, offset and information
That +27 offset will push your rear wheels out about 3/4" so if that's OK w/ you then the tires will fit.
Do you have a pic of the rims by chance?
Wreckreation
Sep 21, 2015 06:27 PM
GFTW
Sep 19, 2015 03:52 PM
gdaelemans
Sep 15, 2015 12:20 PM
Detailed Image
Lighting/Cleaning Products
Sep 14, 2015 07:24 AM
gdaelemans
Sep 13, 2015 09:36 PM
