Spacers
Old Apr 8, 2014 | 04:25 PM
Luckymike74's Avatar
Luckymike74
Spacers
Just bought coil overs for my XS would like to keep my stock 19 in rims, what size spacers do you guys think would look good w the lowered look
Old Apr 8, 2014 | 06:10 PM
inknartg37's Avatar
inknartg37
20mm all around will sit perfect.
Search function is your best friend.
Old Apr 8, 2014 | 11:36 PM
~Lefty~'s Avatar
~Lefty~
Running 20mm here in the rear. 15mm in the front.
Old Apr 8, 2014 | 11:37 PM
Jensen Mathew's Avatar
Jensen Mathew
i thought it was 20mm up front and 15mm in the rear?
Old Apr 8, 2014 | 11:47 PM
Gio37's Avatar
Gio37
Some of the spacer size has to do with the tire size you are running and the look you are want. Some people like to run a little wider rear tire so they get a 20 for the front and 15 for the rear to keep the flush look.
.02
Old Apr 9, 2014 | 12:31 AM
Luckymike74
So will 15 in front and 20 in rear make it look flush or should I go 20/20
Old Apr 9, 2014 | 11:58 AM
inknartg37's Avatar
inknartg37
20mm all around is what I ran, Here are some pics of it with Eibach Springs
https://www.myg37.com/forums/private...m-spacers.html
Old Apr 9, 2014 | 03:04 PM
Luckymike74
Is there a certain brand spacer I should get? Thanks for the help
Old Apr 9, 2014 | 03:28 PM
inknartg37's Avatar
inknartg37
I just usually go with Ichiba V2
Old Apr 9, 2014 | 03:38 PM
O2ShootTheJ's Avatar
O2ShootTheJ
I'm running 20 front 15 rear and am happy with the look! Can grab pics if you would like I'm on swift springs
Old Apr 9, 2014 | 04:12 PM
marinse's Avatar
marinse
I'm selling 2 pairs of 20mm if you're interested for $100 shipped.
Old Apr 9, 2014 | 05:57 PM
Luckymike74
could you share those pics that would be great thank you
Old Apr 10, 2014 | 11:32 AM
inknartg37's Avatar
inknartg37
go 20mm all around, it won't poke out at all. Some people even go 25
Old Apr 10, 2014 | 11:45 AM
randyg37s's Avatar
randyg37s
i went 25mm all around H&R with no rubbing, here are some before and after pics https://www.myg37.com/forums/picture...fter-pics.html
Old Apr 10, 2014 | 10:26 PM
MoonliteMadness's Avatar
MoonliteMadness
As others have stated, go with 20mm all around. I have an xS coupe with the stock 19-inch sport rims and the 20mm spacers look great.
