Thoughts on Rims and Tires?
Old Jul 28, 2014 | 02:24 PM
greydmv's Avatar
greydmv
Hey Guys,
I am leaning towards these Stance ST1s, staggard set up of 20x8.5 et35 fronts and 20x10 et38 rear. My question is will this fit clear the Sport Sedan Akebono brake Caliper? Secondly, what is the most tire that I can get on these? I live in an area that is not very good at maintaining the roads. I am currently not lowered however I will want to lower in the future, most likely using a coilover.
Thank you in advance,
Grey
Old Jul 28, 2014 | 04:25 PM
Originally Posted by greydmv
Hey Guys,
Grey
You'd have to contact the vendor for Akebono clearance, you can also email them this template
http://www.conceptzperformance.com/i...akeoutline.pdf
The +35 in front will be fine on a 245/35/20 and the rear will poke a bit w/ 275/30/20 but will tuck inside the fender under compression. That rear offset won't look right until it's dropped.
Mattlorentzoe
May 24, 2021 08:49 PM
james6980
Oct 9, 2015 01:28 PM
Xenolith666
Sep 20, 2015 08:53 PM
mitchlt
Aug 20, 2015 03:44 PM
