Can't find anything on this tire size
Old Jul 14, 2014 | 12:33 AM
Franciswildcat's Avatar
Franciswildcat
Going with 19x9.5 on front and 19x11.5 in rear on a 2011 xs sedan. now trying to figure tire size. Thinking 275/30 front and 305/30 rear. Is the rear going to fit or is that to wide? Anybody running that set up?
Old Jul 14, 2014 | 12:45 AM
'11G37S's Avatar
'11G37S
A 1/4 mile @ a time
One of the forum members is running 305 rears and I think she's running 250 fronts. I don't know how it would work out with the awd system though...
Old Jul 14, 2014 | 12:56 AM
Franciswildcat
Thanks. Those look like 20's. Am I wrong? Also looks crazy agressive. Maybe I should rethink my approach.
Old Jul 14, 2014 | 01:01 AM
'11G37S's Avatar
'11G37S
A 1/4 mile @ a time
Yes, shes running 20's, I asked her about this set up and she said that its a very tight fit. Most people run 245 front and 275 rears but with the awd system it may mess up the computer if you try to stagger the setup, you may want to research it some more before doing it.
Old Jul 14, 2014 | 01:03 AM
Franciswildcat
Thanks. I appreciate the input.
Old Jul 14, 2014 | 08:32 AM
9.5/11.5 is crazy aggressive unless you plan on other work like fender pulling, heavy camber and slammed suspension.
For a Daily driver I'd go 9 front 10.5 back max.
You MUST be very careful in tire/wheel selection for AWD, the only 19 tires that should be used would be 245/40/19 & 285/35/19 OR
235/40/19 & 275/35/19
Both these combos are under .62% variance
For 20s it should be 245/35/20 & 285/30/20 OR
235/35/20 & 275/30/20
Both these combos are .07% variance which IS the best you can do.
With all those tire sizes listed you must have the proper width rim for a standard mount so 8.5 to 9" front, 10 to 10.5" back. If you go too wide on the rime the mount will be stretched which changes the diameter.
Always use this calculator when trying new tire/wheel setups
https://www.myg37.com/forums/tire_rim_calculator.php, w/ AWD you need to be under 1% variance and really as close to zero as possible.
Old Jul 14, 2014 | 09:12 AM
ChinkyChoy's Avatar
ChinkyChoy
everything blnewt said!
also don't forget that Natalie is on air too
Old Jul 15, 2014 | 04:41 PM
Need 4 Speed's Avatar
Need 4 Speed
Definitely do research. That really is a crazy aggressive fit. 20x9/10.5 is a money setup!
Old Jul 15, 2014 | 04:47 PM
da mayor's Avatar
da mayor
AWD you will have future issues w/ the transmission but 11.5 wide better have the rear custom pulled or cut
Mattlorentzoe
May 24, 2021 08:49 PM
jayrdong
Oct 25, 2015 10:00 PM
connoisseurr
Sep 20, 2015 04:14 PM
Hiryuu
Aug 7, 2015 07:08 PM
Rubyq60
Aug 3, 2015 10:36 PM
