Wheel fitment problem
So' I've got a set of Incurve IC-s5's, 20x9+35F,20x10.5+45R ..
The center caps on the rear wheels are hitting the axles..(I've contacted InCurve they say they only sell 1 style centercap (http://incurvewheels.com/wp-content/...lver-named.jpg) which are like metal-ish and have a rubber gasket in the back which sits into a lip inside the wheel center to stay in. Unlike most center caps ive seen which are plastic and have a metal ring which is like spring loaded that keeps it in (ex: http://c1552172.r72.cf0.rackcdn.com/402416_x800.jpg)
my rear tires are 275/35/20, which I know are a little too tall, but shouldn't effect the width(just making sure this isn't an issue outside of the speedo)
A friend of mine is running Velgen 8's , 20x9+35F,20x10.5+45R with no problems. (275/30/20 in rear)
I threw a +5mm wheel spacer on my rear to try and make room, but it would leave the fender to hit the tire.
Is it safe to shave down the ends of the axle?
I can't figure out how to get these to fit considering other people have these on their sedans without a problem?
ex: https://www.myg37.com/forums/private...preferred.html
Funny thing is, im able to fit his velgen caps into my incurve wheels, and they fit flush without a problem, so im clueless to whats happening. I should have compared the thickness of both the center caps maybe, but something still seems off with my car not fitting the correct ones like everyone elses sedans;
There's been a few members that have had this problem, I'm not sure if it was just InCurve caps or not though.
Any chance you could shoot a couple pics of those caps, and even better if you can also include a pic of the Velgen cap for comparison. I imagine the caps' prongs are too long on the InCurves and if that's the case you may be able to shorten them w/ a dremel tool.
The incurve doesn't have prongs.
my centercap
It's solid, with a gasket at the edge that seats in a lip inside the wheel;
my centercap
my centercap
my centercap
G/L and sorry to hear of the issue
I don't know, the 5mm is gonna run the fender ANC in not sure if the 3mm will give the center cap clearance.
No one with incurves adds their comments so I'm clueless. The vendor says they don't make any other center caps and they fit other sedans with my specs.
I guess my concern is would shaving the axle cause vibrations?
Bc I can always do that to get the caps in
If i go slimmer on the spacer the center cap is gonna hit,
Is there anywhere i can get like blank centercaps with the prong/spring style seating? I could care less if it says incurve, just want somehong thatll fit, like my buddies velgen caps in my wheels..
imgur: the simple image sharer
My axles look normal at least?
I'll try to buy a **** pair from pepboys to see if 3mm will work, if they do il buy a real good fitting set. I got the custom 5mm made so it has the hubcentric ring built in since they are a 73mm center bore wheel;
Hopefully when I get these 3mm spacers it all fits, I've promised newt pictures of the IC-S5's since i've picked them up....like 5 months ago heh.
Had to turn down photo chances because i don't feel comfortable missing the center caps :X
WillCo1
Aug 25, 2015 02:25 PM
