need help pls wheels and tires
Old Jun 25, 2014 | 03:40 PM
GoFightNguyen's Avatar
GoFightNguyen
Because Racecar
Originally Posted by mkkands
Last question if I run 245/40r20 and 275/35r20 do you think I can only drop my coupe an inch and save on the camber kit and avoid rolling or pulling fenders.
I seriously doubt that's really your last question!
The idea that dropping less than an inch isn't a rule so much as a guideline. Lowering your car at all will increase the amount of camber, that's a fact. It's pretty livable/within spec at around an inch, but any more generally requires you to fix it.
You probably won't need to roll your fenders or pull them, just make sure your wheels have the correct sizing! I'm pretty sure 245 and 275 are the max you can fit on the stock wheels, so you shouldn't run in to issues. You'll just have a nice meaty tire.
Old Jun 25, 2014 | 05:02 PM
To keep your rolling diameter similar to your OEM diameter I'd run 245/35/20 & 275/30/20. The sizes you listed will run about 3.5% larger in diameter which may cause problems.
Old Jun 25, 2014 | 06:34 PM
mkkands's Avatar
mkkands
Thanks guys I'm very cautious when taking decisions so I don't want to make the wrong one
Old Jun 25, 2014 | 06:35 PM
mkkands's Avatar
mkkands
Thanks guys just don't want to make the wrong decison
Old Jun 25, 2014 | 11:35 PM
speedracer g37's Avatar
speedracer g37
The fenders and quarters are already rolled. I think the dimensions you listed all fit fine.
BOXER83
Aug 24, 2015 10:42 AM
dAgent
Aug 19, 2015 06:49 PM
infamouslkv
Aug 9, 2015 08:20 PM
