Help wheel gurus!!! Sedan offsets
I have a 12' G37 sport sedan. I have my ride height to where I'd like to keep it. It's lowered on stance coilovers 26.6" front & 26.75" rear. My camber is at 1.6 front & 1.1 rear. I don't mind going 2.0 in the rear & I don't have the front camber arms so I'm stuck with the front camber until/if I need arms. I'm about to purchase some Work Gnosis wheels 20x9.5 +28 R disk & 20x10.5 +32 O disk. Are these offsets going to be too aggressive given my info above?
If you want to keep your camber closer to spec I'd go +40 front +45 rear, if you go excess caber those 32/36 should squeeze in but will be close. IMO you'll avoid issues long term if you go w/ slightly more conservative offsets, and you can go wider rubber in the back that way if you ever want to.
I'm thinking of running 20X10 +43 square and wondering if 275 or 285/30 would be too greedy on the front.
I am using 245/35/20 and 275/30/20 lowered on H&R springs. I dont know the camber degrees but my guess would be that the rear would be between 1.5-2.2 degrees negative camber. A 20x10 +43 with a 275 tire might rub up front so it might be a good idea to go 265/30/20
I'm going off of the offsets on Docaam's pic thread. It says +35, but he told me the rear was +32. I don't know if my height & alignment will be the same as his so that's the reason for my concern. I like how his wheels fit... take a look, but I'm sure you've all seen it.
Allando,
What offset did you finally go with? And what disk type did you get? I'm surprised nobody pointed out that the O-disk and R-disk you wanted requires spacers. Curious to know what spacer size you went with too.
Ihtbealexxx
Aug 9, 2015 03:30 AM
