Spacers
Apr 11, 2014 | 07:29 AM
Quote:
Originally Posted by
MoonliteMadness
As others have stated, go with 20mm all around. I have an xS coupe with the stock 19-inch sport rims and the 20mm spacers look great.
thank you they "20mm" are on the way!!!
Apr 11, 2014 | 12:42 PM
inknartg37
What tire shine is that??
Apr 15, 2014 | 01:32 PM
here is a side view of the stock wheels with 20mm
Apr 15, 2014 | 02:25 PM
Apr 15, 2014 | 09:55 PM
Luckymike74
could you share those pics that would be great thank you
sorry just saw this, looks like you already placed your order. I'm sure you will be happy w/ 20mm all around!
Jul 30, 2014 | 01:29 PM
can someone tell me if you have to shorten the wheel studs if I run 20mm spacers with the 19in sport rims ? 2012 xs coupe..
Aug 1, 2014 | 03:19 PM
Also - related question. If you install 20mm spacers X4, prior to lowering will the suspension require camber adjustment due to wider stance?
I intend on lowering eventually but pondering getting spacers first...
Aug 2, 2014 | 02:19 AM
GS07
Spacers shouldn't have any effect to the camber/toe.
You'll be fine.
Kojack
Oct 9, 2015 05:53 PM
faze2988
Oct 7, 2015 12:05 AM
VQCrew
Sep 26, 2015 01:19 PM
nbast
Sep 14, 2015 12:39 PM
Thirty_Seven
Sep 14, 2015 09:07 AM
