235-50-18 vs 225-50-18 tires
Old Mar 18, 2014 | 10:23 PM
sawfiler's Avatar
sawfiler
Looking to fill the wheelwells a bit better on a totally stock AWD setup. Is this an option?, and is it even worth it or should I just stick with stock.
I understand that the diaemter is a bit bigger so speedo would be off a bit and weight also, but is this a good alternative? I dont want to go any wider as I do alot of highway driving and dont need even worse fuel consumption.
Old Mar 18, 2014 | 10:56 PM
If you want to go wider use a 245/45/18, it can mount on a 8-9.5" rim and your diameter will only differ fromn your OEM diameter by -.66%, much better than the 235s which will be off by 1.45%. I believe your OEM wheels are 8x18, but IF they're 7.5x18 you should stay w/ the 225s.
Old Mar 19, 2014 | 08:35 AM
Carfanatic's Avatar
Carfanatic
Smile
Agreed, The diameter must be < 1 for the AWD model, as if it's more 90% probability AWD light on dash "as AWD system will over heat"
Best of luck !
B Feelgood
Sep 1, 2020 02:50 PM
RYs06MT
Apr 22, 2016 11:00 AM
bri
Nov 23, 2015 11:35 PM
mmnjtwa
Sep 7, 2015 02:27 PM
footballmania32
Sep 4, 2015 03:06 PM
