Tire size question
Old Feb 28, 2014 | 12:50 PM
Hendogg1111's Avatar
Hendogg1111
Tire size question
I'm planning on getting the vmr v710's in 19x9.5 +22 all around. I've been researching and found that they should fit fine without any issues. My car is lowered on coils. As for the tire, I don't know what size to get. Anyone know an ideal size for a flush fit?
Old Feb 28, 2014 | 04:33 PM
Those aggressive offsets will insure a flush fit, you'll have to run a slight stretch IMO to keep from rubbing the inner front fender and if you want the same size all around 245/40/19 would be OK, you still might have to roll the front fenders though depending how low you drop your coils.
Old Feb 28, 2014 | 05:10 PM
Hendogg1111
I'm lowered about 1.5" right now. Would the rears be flush with that offset?
Old Feb 28, 2014 | 08:00 PM
rm2342's Avatar
rm2342
In for pics, although the drop will probably be too low...
Old Feb 28, 2014 | 10:25 PM
Hendogg1111
Current height
Old Feb 28, 2014 | 10:30 PM
Hendogg1111
On second thought, I might get staggered 8.5 fronts cuz newt said I would possibly need a fender roll..it's just cause I was thinking about rotating them.
Old Feb 28, 2014 | 11:43 PM
Here's the VMRs on a sedan, and these are 19x10 +25 running stretched 235/35/19s according to this post
https://www.myg37.com/forums/3479033-post1.html
those are pretty narrow sidewalls for the X.
Here's a thread w/ 9.5" +33 but had to be redrilled for proper bolt pattern
https://www.myg37.com/forums/private...tml?styleid=50
The VMRs are a nice looking wheel, they just don't come in a range of offsets in the Infiniti bolt pattern. If you want an easier fit you might try
a different brand wheel.
This would be an option for a square 9.5" setup w/ +40 offset
https://www.myg37.com/forums/3535854-post1.html
More options
https://www.myg37.com/forums/wheel-a...bers-only.html
You get the idea, check the wheel vendor pages for countless others
Wheel & Tires - MyG37
Old Mar 1, 2014 | 03:12 AM
Hendogg1111
More options
Ooo, thanks a lot blnewt
Old Mar 1, 2014 | 05:01 PM
rm2342's Avatar
rm2342
Current height
Hmm not bad... I'm not one for the tucked look. I like an even drop with flush wheels. That should look just about even with the right set of wheels.. Now go get em!
Mattlorentzoe
May 24, 2021 08:49 PM
jayrdong
Oct 25, 2015 10:00 PM
connoisseurr
Sep 20, 2015 04:14 PM
Hiryuu
Aug 7, 2015 07:08 PM
Rubyq60
Aug 3, 2015 10:36 PM
