Tires for 19" wheels
Old Feb 27, 2014 | 09:38 PM
T's Time's Avatar
T's Time
Just got 2011 base sedan. Want to put on 19" coupe wheels but what size tire fits best on the sedan with 19's? Thanks, T
Old Feb 27, 2014 | 09:46 PM
connoisseurr's Avatar
connoisseurr
X-drive or RWD?
Old Feb 27, 2014 | 09:55 PM
T's Time's Avatar
T's Time
Rear wheel drive
Old Feb 27, 2014 | 10:57 PM
AMai1215's Avatar
AMai1215
Stock size is 225/45/19(fronts) and 245/40/19(rears),
Other members from this forum have put 245/40/19(fronts) and 275/35/19(rears). I'm considering doing this set up as well.
Old Feb 28, 2014 | 12:25 AM
Deelow's Avatar
Deelow
I'll be mounting those sizes on my set of coupe wheels tomorrow. I'll post pics in my build thread tomorrow.
Old Feb 28, 2014 | 05:09 AM
connoisseurr
Stock size is 225/45/19(fronts) and 245/40/19(rears), Other members from this forum have put 245/40/19(fronts) and 275/35/19(rears). I'm considering doing this set up as well.
Using the 245F/275R setup is only for the guys who have AWD.
OP could get away using the stock sizes you mentioned above (225F/245R).
Old Feb 28, 2014 | 07:05 AM
rks's Avatar
rks
I run 245/275 on my summer wheels. I'm not sure where you read that 245/275 is only for the X. OP could get non-staggered coupe wheels and run a square setup as well.
Old Feb 28, 2014 | 07:40 AM
connoisseurr
I guess I didn't mean only, however those tire sizes are meant to keep the rotational diameter difference under 1%. This is necessary for the X-drive system.
RWD can really use whatever tire sizes.
Old Feb 28, 2014 | 06:17 PM
Deelow's Avatar
Deelow
Conn is correct. I'm running 245/40/19s and 275/35/19s. I can now direct you to my build thread where I have coupe 19s on my G.
Old Feb 28, 2014 | 08:54 PM
rks's Avatar
rks
even with RWD you still have to keep rolling % in check or you can screw up the ABS & TC.
Old Mar 1, 2014 | 12:20 PM
Deelow's Avatar
Deelow
I am pretty sure it's within 3% for RWD cars. The closer to stock rolling diameter the better.
Old Mar 1, 2014 | 01:42 PM
Deelows sizes are within 1%
WolfSongX
Car Care & Detailing
May 10, 2017 07:26 PM
04G35NYC
May 2, 2016 05:15 PM
james6980
Oct 9, 2015 01:28 PM
ddayeg37s
Aug 9, 2015 07:10 PM
Hiryuu
Aug 7, 2015 07:08 PM
