19x8.5 front 20x10.5 rear?
Old Feb 16, 2014 | 09:32 PM
Used2BaHEMI's Avatar
Used2BaHEMI
Just looking for opinions.
Old Feb 17, 2014 | 02:24 AM
evil-G-nius's Avatar
evil-G-nius
That's what you want to run? That setup would be so out of spec your car would hate you! It would look ridiculous too, why was that a choice?
Old Feb 19, 2014 | 09:28 PM
Used2BaHEMI
I've seen 18 front 19 rear on an M3 and a couple other set up's and it looked mean so just wanted to know if it had been been done with any G's but if it's that bad then it's no longer an option.
Old Feb 19, 2014 | 09:57 PM
You'd have to run the same sidewall height on the F&R tires for it to look right meaning you'd have a front tire an inch shorter w/ significant diameter difference front to back. More than likely it will cause conflict w/ some of the sensors such as the ABS, but not sure. If it is an AWD it will definitely conflict w/ the AWD operation.
Old Feb 20, 2014 | 10:21 PM
Used2BaHEMI
Yea doing a little more research it wouldn't be a good idea. It was just a brain storm, thanks guys.
Old Feb 22, 2014 | 03:30 AM
evil-G-nius
Sorry if my post sounded...bashy. I was just saying with the VDC being tempermental (apparently) it would hate that setup. And the ridiculous comment...that was all my opinion. LoL. Sorry about that
Old Feb 22, 2014 | 09:14 AM
Synolimit's Avatar
Synolimit
There'd be zero issue as long as the tires are same height (within 0.3"). Don't know while everything thinks wheels matter. That's not whats rolling you down the road and doing the revs per miles.
Only thing I'd worry about is offset and width. A 10.5" rear might not look good with a low offset since the G doesn't have wide fenders like a Z has.
You'll need a 235-265 front tire and a 285-320 rear tire for those widths.
Here pick two within 0.3"
Old Feb 23, 2014 | 04:39 PM
Used2BaHEMI
LOL I take criticism fairly well man, I wasn't at all offended. Thats why I asked in the first place!
e92ry
Dec 31, 2015 08:02 PM
Intake
Dec 25, 2015 09:38 PM
Jensen Mathew
Aug 16, 2015 08:06 PM
GARRYDG07
Aug 11, 2015 08:32 PM
