Wheel fitment
Wheel fitment
Ok, ok, before anyone says to use the search button, I have been reading for hours and there is no real consensus.
I have a 2012 G37S coupe. I am looking at a set of TSW wheels that are 19X8 and 19X9.5 F/R and both have a +40 offset. I may be lowering on Eibach springs and this is my daily driver.
I need opinions on these offsets?
With an Eibach drop those are very high offsets. What I would suggest you do is one of 2 things. 1. Either go with a 19x9.5 +25 all around with a 245/40/19 tire up front and a 275/35/19 rear, or try to find a wider rear something like a 19x10 or 19x10.5 with a +30 or +35 and use the wider tire size on the back. This will give you a flush look with the natural camber that comes with the drop. Also since you have a coupe it is wider front and back so it will accommodate a more aggressive fitting. Let me or Brad aka blnewt know if you need any help picking offsets
Hollywood619 (02-06-2014)
