Help with g37x fitment
Old Nov 21, 2013 | 06:08 PM
under6ft's Avatar
under6ft
Newbie here needs some help. Just bought a G about a month ago and I am going to need some new tires, so might as well upgrade from the stock setup.
I found a pair of used TSW Jerez wheels for a good price, but not sure if they will fit. (2x)19x8.5 +20 offset (2x) 19x10.5 +27 offset
I am sure the front wheels would be fine, how about the 10.5 rears?
I am planning on lowering using swift springs in the near future
Thanks for your help.
Old Nov 21, 2013 | 10:40 PM
If you've got a coupe it'll be OK (they'll poke a little until you lower it) but too aggressive for a Sedan. You may have to run a bit stretched in the back, something like a 275/35/20 w/ a 245/40/19 front. Ideally a 285/35/19 will give you the closest diameter to OEM but it may be too close to the fender edge.
helloandchau
Oct 6, 2015 05:26 PM
ArmyBoyd
Sep 22, 2015 08:54 AM
ay37
Sep 15, 2015 08:51 AM
Dillybar12
Engine, Intake and Exhaust
Sep 14, 2015 12:54 PM
mmnjtwa
Sep 7, 2015 02:27 PM
