2010+ G Sedan S w/Bbk and aftermarket wheels.. HELP
Old Sep 4, 2013 | 09:56 PM
rare37s's Avatar
rare37s
Those with sedan sport with bbk and aftermarket wheels, did you HAVE to roll or cut fenders and add spacers just to put 20s staggered. I want to avoid doing any rolling or cutting of fenders if possible. My near future plan is to lower on eibach pro's. What wheels do you guys have or where can I find wheels that will fit w/o modifying fenders. Ive only had the car a month and this is becoming annoying to find wheels that will clear. SO Far
LM (BBS) style 20x9 +15 & 20x10.5 +20 245/275 tires (roll of cut front fender)
TSW Zolder 20x8.5 +35 & 20x10 +42 245/275 (salesman said they SHOULD clear but wasnt 100% sure)
Car is on stock suspension.
Old Sep 4, 2013 | 10:15 PM
rks's Avatar
rks
clearing the BBK involves offset and spoke design. I'm on 19"s and I know a number are on 20"s without any fender modification while being lowered. The sales person should absolutely know which wheels clear. I think your bigger issue is going to be camber/toe if you get too aggressive.
Old Sep 4, 2013 | 10:22 PM
The second set of wheels you listed has proper sedan offsets, the first set is way too aggressive and you'll have to do a lot of work to get them to fit & look right. Just save the headaches and get offsets similar to your second set, just be sure w/ the vendor that they'll clear Akebonos. Here's a couple templates you can shoot to the vendor if they're not sure~
http://www.conceptzperformance.com/i...nttemplate.pdf
http://www.conceptzperformance.com/i...artemplate.pdf
FWIW there's plenty of wheels that will clear without any modifications, the main thing is find wheels w/ the correct offset then make sure those wheels will clear. Also check the following threads for combos that will work for your S.
https://www.myg37.com/forums/picture-share-g-sedan-376/
https://www.myg37.com/forums/g37-sed...ur-sedans.html
https://www.myg37.com/forums/wheels-...fat-tires.html
m1cha3l
Buying & Leasing
41
Mar 9, 2019 12:56 PM
BANNISTER
Dec 10, 2015 04:14 PM
m3clubracer
Aug 26, 2015 07:36 AM
Madorable
Aug 21, 2015 09:49 PM
Spicy_Kimchee
Aug 11, 2015 09:10 AM
