Wider Tires On Stock Wheels
Old Apr 2, 2013 | 02:43 PM
Quatro's Avatar
Quatro
Hey guys, I know this is a newb question but I have heard of a few people putting wider tires on the stocks wheels.
I was wondering if anyone could verify this and if so what sizes could you run?
Old Apr 2, 2013 | 02:50 PM
TVPostSound's Avatar
TVPostSound
You can go 245 fronts, and 275 rears.
See below:
Old Apr 2, 2013 | 04:51 PM
Quatro's Avatar
Quatro
Did you have any rubbing? And was turn in/handling any better because of it?
Old Apr 3, 2013 | 01:26 PM
terribleone's Avatar
terribleone
I believe the only way you will rub is if you are lowered to a certain point and have spacers on your OEM wheels.
Old Apr 3, 2013 | 01:35 PM
TVPostSound
What he said!!^^^^
Im lowered 1 1/2" with 20MM spacers, I rub slightly on heavy dips in the rear!!
15MM spacers, wont rub. Even lowered.
Old Apr 3, 2013 | 07:47 PM
philter25's Avatar
philter25
https://www.myg37.com/forums/wheels-...er-sports.html
You wont rub with larger tires unless you have spacers.
Old Apr 5, 2013 | 03:48 PM
Neal@tirerack's Avatar
Neal@tirerack
MYG37.COM Platinum Sponsor
Very common upgrade on the oem 19's is 245/40-19 and 275/35-19.. Fits fine and looks great.
Old Apr 26, 2013 | 04:54 PM
mpegripper's Avatar
mpegripper
same deal if you put those wheels on a sedan?
Old May 22, 2013 | 06:50 AM
techG37elec's Avatar
techG37elec
HI. Just purchased a 2010 Journey Sport with factory 19" rims. I searched the threads but saw no mention of 285/35/19 for the rears as an alternative. I was speaking with a guy from tirerack and he suggested this size. (I will use the 245/40/19 for the front)
Anyone know if this is OK? BTW, I'm looking at using the Bridgestone Potenza SO4 Pole position.
Thanks...
Old May 22, 2013 | 08:51 AM
Thanks...
You'll be fine w/ the diameter as it's only .51% different than oem size. Tires will be a bit pinched which may cause a bit more center tread wear but the extra bulge at the sidewall is a good rim protector
Old May 22, 2013 | 12:02 PM
techG37elec
Thanks.... wife thinks she's driving it so I will need protection.
amciner28
Sep 7, 2015 08:50 PM
drewfinity
Aug 20, 2015 08:17 PM
mitchlt
Aug 20, 2015 03:44 PM
ddayeg37s
Aug 9, 2015 07:10 PM
Hiryuu
Aug 7, 2015 07:08 PM
