9.5" or 10" wheel with a 275
Old Feb 25, 2013 | 01:32 PM
pgviper's Avatar
pgviper
Getting a set of 19" VMR V710. 8.5 F and 10 R.
Planning on running 245 F and 275 R.
Now I'm second guessing if I should go with the 10" rear or a 9.5" rear.
Opinions?
Old Feb 25, 2013 | 02:27 PM
Sunny G's Avatar
Sunny G
Why don't you go 9 front and 10 rear? With a 245/275 setup. What kind of offsets you looking at? Let me know maybe I can help.
Old Feb 25, 2013 | 02:30 PM
LegitMW's Avatar
LegitMW
From the sizing and offsets I've seen vmr offer, i suggest you go 9/10 or 10/10.
Old Feb 25, 2013 | 02:34 PM
pgviper's Avatar
pgviper
Thanks for the help.
Wheels:
Front: 19 x 8.5 + 35
Rear: 19 x 9.5 + 25 or 19 x 10 + 25
Tires:
Front: 245/40/19
Rear: 275/35/19
Not planning on dropping the car or doing any type of suspension modifications so I really want to keep this setup as close to OEM specs as possible in order to avoid the jacked up 4x4 look.
Old Feb 27, 2013 | 12:33 PM
pgviper's Avatar
pgviper
Currently they are out of stock so my other option is to switch to a 19x9.5 22mm & 19x10.0 ET25mm setup.
Will I have any rubbing issues running 245/40 front tires and 275/35 rear tires?
Old Feb 27, 2013 | 12:38 PM
bluedevils95's Avatar
bluedevils95
I would try to keep the size pretty close if you can. the 9/10 would be good
Old Feb 27, 2013 | 12:43 PM
pgviper's Avatar
pgviper
How come the offsets of the VMR V710 wheels are soo much less than the offsets of the stock wheels. Is it because the VMR wheels have a concave wheel design?
VMR V710's don't come as a 9" wheel. Only 8.5 or 9.5.
Old Feb 27, 2013 | 12:59 PM
Jamler's Avatar
Jamler
@ 275 you'd be fine with either 9.5" or 10"
I'm actually running 285s on rear stock rim... It's a little tight but no issues.
Old Feb 28, 2013 | 09:47 AM
pgviper's Avatar
pgviper
I went with Avant Garde M310 19 x 8.5 running a 245 up front and 19 x 9.5 running a 275 in the rear. I'll post pics as soon as I get everything on.
Old Feb 28, 2013 | 10:23 AM
ZOSTER33's Avatar
ZOSTER33
You're not going to have any rubbing issues except that you will have that 4x4 look since you are not dropping your G.
helloandchau
Oct 6, 2015 05:26 PM
fysemi
Oct 2, 2015 04:06 PM
xpcgamer
Sep 7, 2015 07:10 PM
Sylo
Sep 3, 2015 04:44 PM
